JD modle 212 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by vcassens, this thread has received 7 replies and been viewed 8374 times.
post #1 of 8 (permalink) Old 02-05-2010, 04:29 AM Thread Starter
vcassens's Avatar
JD modle 212
hey guys I got a JD modle 212 for free and it runs and mowed when I got it but the bearing was pulling out of the deck du to rust wich I am going to fix but one of the bearing bolt ears broke and I need to get an entire bearing assembly,neew belts and a few other thing and am looking for a place to get them other than the JD dealer any ideas thanks
2004 ford F350 6.0L 6 speed manual,SCT live wire,south bend double disk clutch,short throw shifter fx4. Costome exhaust 4 inch turbo back to 5" homade stacks, banjo bolt mod, shimed regulator,custom leveling kit (not blocks) and air lift air bags with onbord air suply TRADED FOR
2006 ford F 250 Amarillo 4" turbo back other than that stock for now
singles club #206
bomb squad #67
Ridin' Dirty Club #65
vcassens is offline
post #2 of 8 (permalink) Old 02-05-2010, 05:20 AM
ADMIN/MAFIA
neeltburn's Avatar
I redid all of the mower deck spindles this past year on my JD mower. I don't think you will have many other options than deere. Have you called deere and ask about parts? Which bearing is it? Do you have the model number for the mower deck. When I search 212 through the JD parts index I can not find the mower deck?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
vcassens (02-05-2010)
post #3 of 8 (permalink) Old 02-05-2010, 06:18 PM Thread Starter
vcassens's Avatar
thanks I will see what I can find
singles club #206
bomb squad #67
vcassens is offline
post #4 of 8 (permalink) Old 02-06-2010, 02:07 AM
bmoeller's Avatar
If you have bearing numbers, you might be able to go to a bearing supplier and get them. We have 2 places here to get most of what we need.
As for belts. Don't skimp. A&I belts are flat out JUNK! Didn't even get 20 hrs out of some of them. Flew apart and trashed a big harness. Been there, done that!
Go to NAPA or Carquest and get Gates belts.
"Obama = Hoax and Chains"
bmoeller is offline
vcassens (02-06-2010)
post #5 of 8 (permalink) Old 02-06-2010, 02:53 AM Thread Starter
vcassens's Avatar
thanks I never thought about that I live about 5 miles from a bearing headquarters store and I am prety shure that all three bearings are the same on the deck. I guess I will have to compare the 2 that I have and see and if they are I am ready to mow come spring not bad for a free mower
singles club #206
bomb squad #67
vcassens is offline
post #6 of 8 (permalink) Old 02-08-2010, 05:01 AM
bmoeller's Avatar
I got a "free" 111, but it needs an engine. Someone managed to knock the engine oil drain plug out of the engine. Ran it out of oil. How the hell you miss that? Right out in the open. Oil would've covered the deck.................
Oh well. Works for me. Near mint otherwise.
bmoeller is offline
post #7 of 8 (permalink) Old 02-10-2010, 07:16 AM
1996 StrokerKid's Avatar
dont skimp on the bearings, if you do you will pay 3 times over before you get a quality bearing.
1996 F-350 LB CC 4 in. lift 35 in. BFG AT's Go Rhino Grill Gaurd, Stancor GPR.
"Id rather be stroked than rammed!"
1996 StrokerKid is offline
post #8 of 8 (permalink) Old 03-31-2010, 02:16 AM
Decks on those 200 series deere's were on their on parts microfiche. You could have a 39 or 47 inch cut and the serial number if I remember would start out as HO39 or HO47. Take the housing with the broke ear and turn it in relation to belt loading to be pushed into the deck. That would be usefull if you can't find a replacement. Expect to cut or break off the 3 bolts if they don't come out easy. I know where there is a new housing here in Killeen texas at an independant mower shop that I worked at last fall.
biotaz is offline
