Drill pump to transfer fuel - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Duke, this thread has received 17 replies and been viewed 17799 times.
post #1 of 18 (permalink) Old 02-11-2010, 07:13 PM Thread Starter
'Ol Builder guy
Duke's Avatar
Can't believe I never had to do this in all my years. I've always fueled up before big storms, but all fuel stations were sold outta diesel , so I picked up one of these little "wayne" drill pumps. Has garden hose threads on the "in" & "out" sides.
Anyone use one of these with a cordless drill to move pump from a truck to my backhoe & my tractor? Is it safe with diesel? Will the internals of the pump stand up to diesel? Will clean garden hose contaminate diesel in the tank?
Probably over-worrying this, but I thought I'd throw it out there.
Duke is offline
post #2 of 18 (permalink) Old 02-12-2010, 12:36 AM
here
John Deere's Avatar
Duke, I think you are OK with the Garden hose, my guess is the pump is going to fail on you, but it may pump enough fuel first to get you by. Sounds like you are stuck between a rock and a hard place and may have to tell us whether it worked or not. UNLESS you happen to have an inline electric fuel pump you can jury rig up to transfer the fuel, it may take awhile, but if the drill pump you bought is anything like the one I have messed with, it won't be a whole lot faster.
Good luck, and stay warm and safe.
Brady
2002 Ford F350 Crew cab, 4x4, XLT, 7.3 Powerstroke Diesel, AIS filter kit, 6 speed, Ali-arc aluminum frontend replacement
88' Ford F250, 4x4, 7.3L Diesel, Banks Sidewinder, 5 spd, flatbed, feed-truck
78' Ford F250 supercab, Dana 60's, C-6 and a slightly modified 400m- dead, soon to be a 460. 6" skyjacker lift with 38.5 boggers, play-truck
John Deere is offline
post #3 of 18 (permalink) Old 02-12-2010, 01:00 AM Thread Starter
'Ol Builder guy
Duke's Avatar
U mean you think the diesel fuel will eat-out the pump internals??
Duke is offline
post #4 of 18 (permalink) Old 02-12-2010, 01:03 AM
Administrator
fordt's Avatar
Images: 5
I think you are worrying too much. If it does eat it out it's going to take a long time.
-Wayne
2007 Chevy LBZ 6.6L Classic
fordt is offline
post #5 of 18 (permalink) Old 02-12-2010, 01:19 AM
bushpilot's Avatar
whats the GPM rating on that drill pump....do some quick math and figure out
how many drill/batteries youll need.
might be good in a pinch or emergency...id be concerned about burning up a
good drill (from continuous use)...most of those pumps ive seen are pretty "cheap".
ever consider something like this -> Northern Tool: transfer pumps
Don R.
Truck Audio,
bushpilot is offline
post #6 of 18 (permalink) Old 02-12-2010, 03:58 AM
The plastic garden hose will last a year at least, the rubber washers about a month - use the plastic ones.
The drill pumps come in different sizes, the small one and the ones with a rotor 2 and 3 in long. The small one is slow.
Transferring with air is much faster if you can pressurise the tank.
The hand pumps, at a quart a stroke, are much faster.
Don't move garden hose back and forth, there will be water in the fuel. I know
81 Isuzu /C223na, 5spd
keydl is offline
post #7 of 18 (permalink) Old 02-12-2010, 12:52 PM Thread Starter
'Ol Builder guy
Duke's Avatar
This one moves 136 GPH.
I really need to come up with a way to keep ~50 gal. #2 on hand. My GMC has a 8'x4' util body. Is there a bed mounted tank that sits between the boxes and up off the floor enough so I can still carry some 8' material?
ID:	24523   Click image for larger version
Duke is offline
post #8 of 18 (permalink) Old 02-12-2010, 01:22 PM
bmoeller's Avatar
Seen some old farmers use 55 gallon drums with a hand pump. Usually steel barrels. The hand pumps are pretty easy to operate and move fuel pretty quick. You could make a cradle to get it up off of the floor to clear some plywood. If you got an empty hyd. oil drum, you're half way there.
"Obama = Hoax and Chains"
bmoeller is offline
post #9 of 18 (permalink) Old 02-12-2010, 02:24 PM
bushpilot's Avatar
ATTA will make you any kinda tank you WANT, and theyre aluminum.
My 50gallon aux/transfer tank only takes up 10 inches of bed depth.
kshmarine is another one that will build you a custom tank
RDS is closer to you (in florida at least), maybe they can fab up an over the rail tool
box style tank...
Don R.
Truck Audio,
The Following 2 Users Say Thank You to bushpilot For this addition to TDG:
Duke (02-12-2010), fordt (02-13-2010)
post #10 of 18 (permalink) Old 02-12-2010, 02:30 PM
here
John Deere's Avatar
Oops, I read your post as if this was something you needed to do immediately.
Brady
Shim transfer pump cat pichu Medium and Heavy Duty 34 12-15-2011 09:11 PM
Cheap Oil transfer pump? RSieck Bio-Diesel/ULSD/Additives Discussions 7 08-04-2009 09:45 PM
Dual Stage Transfer pump Mt.Washington7.3 1994-2003 7.3L Power Stroke 0 01-26-2008 01:06 AM
transfer pump??? hubcap 5.9L Cummins (2003-2007.5) 6 09-02-2007 02:14 AM
Transfer pump question bad_cummins 5.9L Cummins (1998.5-2002) 12 07-29-2006 01:03 AM
