diesel backhoe - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by mae, this thread has received 6 replies and been viewed 1954 times.
post #1 of 7 (permalink) Old 03-19-2010, 02:18 AM Thread Starter
mae
diesel backhoe
We have a 580ck loader backhoe. It's been running great, till today. We were loading some rock and it stopped running. It will start, but won't run. If we are using the hydrolics, it runs. That's the only way it will run. I don't understand how moving the buckets keeps the engine running, but if you don't move one of the buckets it quits. Please help me understand what's up with it.
mae is offline
post #2 of 7 (permalink) Old 03-20-2010, 02:48 AM
I would guess that there is something wrong with the hydraulic system. My first thought would be that when you're not using any hydraulics, the fluid should flow back to the tank on its own. Maybe somehow that flow is obstructed so the hydraulic pump can't push it any more and it stalls the engine out. We had some hydraulic lines that were hooked up wrong on a front end loader so when you tried to steer it it would stall it out. Got the lines hooked up right and fixed the problem. You'd have to trace the lines and see how the oil gets back to the tank if it isn't used. I'm thinking theres some type of valve it goes through that's not working right.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. BDP modded IDM. Heim joint clutch linkage. Adrenaline HPOP. LUK SMFW. DIY Elec. Fuel. FS1282, FF5230 fuel filters.
sdan27 is offline
The Following User Says Thank You to sdan27 For this addition to TDG:
mae (12-18-2012)
post #3 of 7 (permalink) Old 03-20-2010, 07:08 PM
here
John Deere's Avatar
I am guessing that a Case backhoe has an open center hyd. system, meaning the pump is always pumping fluid and there is always fluid returning to the sump. My guess is there is a blockage in the return lines apparently right at the loader control valves.
Will operating the hoe controls also allow it to run?
Doesn't sound like an engine problem to me, and not being familiar with Case hoes, I can only give basic info. Sorry.
Brady
2002 Ford F350 Crew cab, 4x4, XLT, 7.3 Powerstroke Diesel, AIS filter kit, 6 speed, Ali-arc aluminum frontend replacement
88' Ford F250, 4x4, 7.3L Diesel, Banks Sidewinder, 5 spd, flatbed, feed-truck
78' Ford F250 supercab, Dana 60's, C-6 and a slightly modified 400m- dead, soon to be a 460. 6" skyjacker lift with 38.5 boggers, play-truck
John Deere is offline
The Following User Says Thank You to John Deere For this addition to TDG:
mae (12-18-2012)
post #4 of 7 (permalink) Old 03-21-2010, 01:52 AM
Dodgefarmer's Avatar
It is a open center hyd system
singles club # 198
Dodgefarmer is offline
mae (12-18-2012)
post #5 of 7 (permalink) Old 03-23-2010, 02:37 AM
bmoeller's Avatar
Pressure relief might be stuck shut.
"Obama = Hoax and Chains"
bmoeller is offline
mae (12-18-2012)
post #6 of 7 (permalink) Old 03-24-2010, 06:59 PM
If the pressure line runs from the pump to the control valves, bypassing the valves to the tank with a hose will prove the malfuction in the valve. Probably a plugged screen or damaged chevron/o-ring. The pressure relief valve is stuck or it would run and make noise, there may be damage to the pump drive from the overpressure of stopping the engine. Be sure to check the hydraulic fluid and the bottom of the tank for 'stuff', cut the filter to see the element - clean a spot with brake cleaner to look at with a 30x or higher microscope.
81 Isuzu /C223na, 5spd
keydl is offline
mae (12-18-2012)
post #7 of 7 (permalink) Old 03-24-2010, 07:29 PM
To much time....
You may have to drill and tap the pressure relief plug to get it out of the bore, I don't know the location, I haven't done farm/industrial equipment in quite a while. Most of the stuff is the same as on wreckers.
keydl is offline
mae (12-18-2012)
Just bought a backhoe, need help.... BigRed Cummins The Parking Lot 24 12-13-2009 11:02 AM
can your backhoe do this? Sabbath5.9 The Parking Lot 6 02-02-2009 06:34 PM
98 416C Cat Backhoe JT's416cat Utility & Farm Tractors 0 05-03-2008 06:00 PM
BACKHOE advice Duke Utility & Farm Tractors 31 03-29-2008 04:56 AM
Driving backhoe OTR Duke Utility & Farm Tractors 8 02-08-2007 03:34 AM
