DT 414 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kblackav8or, this thread has received 4 replies and been viewed 8079 times.
post #1 of 5 (permalink) Old 03-20-2010, 12:03 AM Thread Starter
I do all my own stunts
Send a message via MSN to kblackav8or
DT 414
What is the story on these engines? Are they the older version of the DT 466 or more like the DT 360? Interested in how they compare dimensionally to the other ones. Might make for an interesting road engine for a old pickup or truck.
2000 F-250 PSD 6 speed 4x4 Lariat
1959 Kenworth CC 925 NTC-400 5x3 4.10 SQHD's
Myriad of parts and pieces in my garage
kblackav8or is offline
post #2 of 5 (permalink) Old 03-20-2010, 05:14 AM
I'm guessing it has the same block as the 466 and 360 with a different bore and stroke to make up the difference in displacement.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. BDP modded IDM. Heim joint clutch linkage. Adrenaline HPOP. LUK SMFW. DIY Elec. Fuel. FS1282, FF5230 fuel filters.
sdan27 is offline
post #3 of 5 (permalink) Old 03-20-2010, 04:41 PM Thread Starter
I thought the 360 had a different block being it is smaller dimensionally then the 466.
post #4 of 5 (permalink) Old 03-20-2010, 05:36 PM
Hacky!
Binderpower's Avatar
Send a message via Yahoo to Binderpower
The dt414's are the same block as the 466's. These were the 400 series engines (414, 436, 466). The only reall difference when they were first built was the stroke. They all had the same bore, just differing strokes, your cranks were different as well. 4.3"bore x 4.75", 5.00" & 5.35" respectively
Why farm half when you can FARMALL!
Give fools their gold, and knaves their power;
Let fortune's bubbles rise and fall;
Who sows a field, or trains a flower,
Or plants a tree, is more than all.- Whittier.
"A Liberal is a person who will giveaway everything he doesn't own
When you subsidize poverty and failure, you get more of both
Diesel Power
Binderpower is offline
The Following User Says Thank You to Binderpower For this addition to TDG:
John_G (03-20-2010)
post #5 of 5 (permalink) Old 03-20-2010, 06:14 PM
Super Moderator
John_G's Avatar
The DT/DTA360 and DT/DTA466 are completely different blocks, heads and cranks; although nearly 70% of the parts numbers are interchangable between the two engines. Same design, but different engine families.
I vote for LIBERTY!
John_G is offline
