need opinions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by buffalobob, this thread has received 3 replies and been viewed 1300 times.
post #1 of 4 (permalink) Old 05-08-2010, 01:29 PM Thread Starter
buffalobob's Avatar
need opinions
need input here. am looking at buying a 686 IH. has a real good westendorf WL42 loader. really heavy. d312 engine. everything works. are these usually reliable. any opinions welcome.
2011 silverado lt, crewcab, short bed, 4X4, d-max/ allison
buffalobob is offline
post #2 of 4 (permalink) Old 05-11-2010, 12:25 AM
Hacky!
Binderpower's Avatar
Send a message via Yahoo to Binderpower
Just curious if you received my pm?
Why farm half when you can FARMALL!
Give fools their gold, and knaves their power;
Let fortune's bubbles rise and fall;
Who sows a field, or trains a flower,
Or plants a tree, is more than all.- Whittier.
"A Liberal is a person who will giveaway everything he doesn't own
When you subsidize poverty and failure, you get more of both
Diesel Power
Binderpower is offline
post #3 of 4 (permalink) Old 05-11-2010, 01:13 AM Thread Starter
buffalobob's Avatar
no i didnt.
post #4 of 4 (permalink) Old 05-11-2010, 11:37 PM
Hacky!
Well I am not sure what happened, but I wrote that this tractor is rock solid. very dependable, easy to use, etc. It came with 66 pto HP and 58 drawbar ponies. Nothing to note about the D312. It is a reliable little engine. They did convert to the D310 Kraut power. If you were to check anything, check out the 3 pt. Make sure it holds pressure, meaning, if you are attaching an implement to it, does it hold or does it settle? Just check the obvious, otherwise, like the pto, hytrans fluid etc. I have operated the 666 which is nearly identical to the 686, besides the model #. Reliable workhorse, utility tractor etc.
Diesel Power
The Following User Says Thank You to Binderpower For this addition to TDG:
buffalobob (05-12-2010)
Need some opinions OFD343 2008-2010 6.4L Power Stroke 15 08-01-2009 05:55 AM
So I need opinions.... shadowgearx 5.9L Cummins 12 Valve (1994-1998.5) 48 02-08-2008 08:21 AM
Need your opinions circle5 1994-2003 7.3L Power Stroke 24 02-06-2008 05:35 PM
