My wounded '95 takes a "hot" 24 valve - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cummins power, this thread has received 2 replies and been viewed 1719 times.
post #1 of 3 (permalink) Old 05-05-2010, 11:27 PM Thread Starter
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
For those of you who haven't heard, my pickup is running about 1/3 low on compression on one cylinder, and as such I am running stock injectors right now but otherwise mods are the same as in my sig. I was running against a 2000 Cummins QCSB 5 speed with Edge Comp, 50hp nozzles, intake, exhaust, and the wastegate blocked off.
Neither of us was ready when the light turned green, so we both left the line no boost and I was in 2wd not sure about him. For about a second, I thought how come my torque band isn't really coming up like normal? Then I realized my valet switch was still in low power mode so I flipped it, got the fuel I needed and grabbed 3rd and chirped the tires, then I started to pull away on him through 4th and we shut down at 45mph being in town and all. Saw him in class today, he isn't talking about his rig like he used to
Logan
Do Or Die Garage Experiment
cummins power is offline
post #2 of 3 (permalink) Old 05-06-2010, 12:18 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
Nice
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #3 of 3 (permalink) Old 05-06-2010, 02:21 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Nice good kill
Military Quote Of The Year
SOOTBANDIT is offline
1998 12 valve Cummins Diesel "Help" ray46don 5.9L Cummins 12 Valve (1994-1998.5) 16 07-21-2009 05:10 AM
The "New Diesel Emissions" prevent the use of a "Jacobs" (jake brake) HARLEY6LF250SDU General Diesel 4 01-17-2009 02:53 PM
Water Drain Valve "o" Rings OILFIELD TRASH 6.7L Cummins (2007.5-2011) 1 01-10-2008 12:54 AM
NBA Headlines Ford: A new No. 1 contender<img src="http://espn.go.com/i/in.gif" width="11" height="11" hspace=4 border="0" alt="Insider"> RSS Feeder The Parking Lot 0 06-09-2006 07:00 AM
Former Marine takes on 5 robbers with his 2" pocket knife TooMuchBoost The Parking Lot 15 06-02-2006 12:55 PM
