1000ft/lbs - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dual K20s, this thread has received 13 replies and been viewed 2512 times.
post #1 of 14 (permalink) Old 09-24-2007, 12:53 AM Thread Starter
1000ft/lbs
I wanted to know what it would take to get my truck over 1,000ft/lbs of torque. I'm in the market for a new turbo so that will defenately be on the list (and suggestions?) but what else do I need to get there? I know peak torque is lower in the rpms so a smaller turbo should help up the toque more than the HP,correct?
I've got a 98 5-speed with 17.5* timing, #100, 4K GSK, modified afc arm, DDP stage 3's and delivery valves, and I might have missed a few things but they should be in my signature.
Dual K20s is offline
post #2 of 14 (permalink) Old 09-24-2007, 01:12 AM
diesel_ram_man's Avatar
Images: 6
What dv's are they? 191's? You should be inthe 450-500hp club (at least once you get a turbo) which should equal out to 1000ft/lbs, roughly. I have heard great things from HTT's 62/13/71ss.
The Diesel Garage.com
Can You Keep Up??
diesel_ram_man is offline
post #3 of 14 (permalink) Old 09-24-2007, 01:17 AM Thread Starter
I'm not exactly sure. I got them at a deal with my injectors, but from their site i'd say they are roughly 191's DDP DV's I don't have them in yet. I'm waiting for the socket and a turbo. But they will be in when the turbo gets installed.
post #4 of 14 (permalink) Old 09-24-2007, 01:28 AM
Diesel Mafia #67
blackcloudCTD95's Avatar
Damn they sound like some good DV's
Jordan
blackcloudCTD95 is offline
post #5 of 14 (permalink) Old 09-26-2007, 03:57 AM Thread Starter
Since mickey quite making his dv's I think I'm gonna send my stock ones off to PDR for some of their Custom taper DVs and compare the two, hopefully on the dyno.
So once I save the money (may take some time, my turbo fund has died 6 times in the last two months: 1 cow out of nowhere, 1 calf caught a virus, 1 cow of an infection the day of the auction, 1 paralized after having twin heifers 1 month early, and the twins died too ) I'm thinkin a HTT 62/13ss and a remote e-brake.
Any other ways to get 1000ft/lbs? What else will I need besides the turbo?:shrug:
post #6 of 14 (permalink) Old 09-26-2007, 04:14 AM
Diesel Mafia #67
I think you migh be there.. if not breaking 1000 foot pounds.. Fuel plate, DV's, injectors, and timing, :Thumbup:
Jordan
post #7 of 14 (permalink) Old 09-26-2007, 05:11 AM
A shot of good ole NOx should do the trick. Cheaper than a turbo too. I don't really recommend doing it, but it should get you there if you are desperate. You could build a kit for around $350, maybe $400.
post #8 of 14 (permalink) Old 09-27-2007, 03:24 AM Thread Starter
No I'm not desperate and I don't want to run injectables. but Its an idea. If a turbo doesn't get me there then I might....but I don't want to
post #9 of 14 (permalink) Old 09-28-2007, 12:31 AM
Bouncer
370's, 4k gov springs, laser cut DV's, 20* of timing, #0 plate, o-ring'd head, .020"+ marine gasket, and a HTT 62/13/71 SS got me there.
Now since I had the pump work done I am curious as to where I am now.
post #10 of 14 (permalink) Old 09-28-2007, 01:21 AM Thread Starter
How much of a difference will 2.5* timing make? other then that I should be pretty close to what you had
