12 v running rough - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Whitemare, this thread has received 5 replies and been viewed 1516 times.
post #1 of 6 (permalink) Old 09-22-2005, 11:34 PM Thread Starter
12 v running rough
Hey guy's, Thanks for all the help last week on my 12v trouble. I talked to Jeff Garmon and he had me run a straight line from my main fuel line to the lift pump (bypassing the fuel heater). It solved my truck not cranking. I got the truck running, but it is still acting the same way beffore i put a new lift pump on it. If i come to a stop it will sit there and run rough. Like its got a massive cam in a big block. If i run the Ac it will die if i come to a stop. Does'nt feel like it has the power it used to have. Also it run,s cool like 150-160. Any help would be great. Thanks Chris. (Tim's Brother-in-law) DONT HOLD IT AGAINST ME. :shrug:
Whitemare is offline
post #2 of 6 (permalink) Old 09-23-2005, 03:02 AM
That guy
thefermanator's Avatar
What thermostat do you have in it? Have you actually put a guage on it and checked the fuel pressure at the pump. Another thing I've seen on the 12V engines is the fuel cutoff solonoid not pulling the cutoff all the way open.
1995 GMC 2500 SUBURBAN, DURAMAX/ALLISON, 3.42 gears, 261 T-case, Trans has a mild build with ALOT of help from MIKE L. which included ALTO's for C1-C4, PI ML converter, DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, EFILIVE, KENNEDY single pump, pump rub kit
http://www.thetruckstop.us/forum/showthread.php?t=10142
thefermanator is offline
post #3 of 6 (permalink) Old 09-23-2005, 03:44 AM Thread Starter
I have not put a gauge on it yet. I just bought a thermostat 180, I have not installed it . Could the cool temp cause any of this?
post #4 of 6 (permalink) Old 09-23-2005, 03:46 AM Thread Starter
Also where is the fuel solonoid located? I was told from somebody the 12v did not have one. :shrug:
post #5 of 6 (permalink) Old 09-23-2005, 05:30 AM
That guy
The fuel cutoff solonoid is the large one on the top of the pump. It has 3 wires going to it. The solonoid is not internal like in the 93-. I don't recall offf the top of my head at this time, but I believe the O.E. temp was 195 but it could be 180. I know if the temp in the cylinders is to low it won't run right. Did you ever drop the tank and replace the screan? You could still be suffering from fuel starvation. If your fuel heater was plugged imagine how much crap is in the tank(the fuel heater got plugged by the stuff that made it through the screen so you know the big stuff is still in the tank). I put in your other thread to drop the tank and check it.
post #6 of 6 (permalink) Old 09-24-2005, 03:10 AM
bmoeller's Avatar
http://dodgeram.org/tech/dsl/trouble..._solenoid.html
"Obama = Hoax and Chains"
bmoeller is offline
Sheep 101.......For Billy bigdraft The Parking Lot 6 09-23-2005 01:20 AM
Well, it happened..... Summit6.6 2003-2007 6.0L Power Stroke 28 09-22-2005 09:13 PM
05E15 Recall UpstateDieselGuy 2003-2007 6.0L Power Stroke 0 09-09-2005 01:14 AM
Boxes, boxes, ecms? Buck1 Dodge Performance Forum 2 08-08-2005 07:53 PM
Thanks For The Forum Guys! bigdraft 4X4 Offroad Forum 8 05-18-2005 03:47 AM
