engine problems - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by floridaboy, this thread has received 16 replies and been viewed 1741 times.
post #1 of 17 (permalink) Old 04-23-2008, 02:22 AM Thread Starter
gone fishin!
engine problems
Does anyone else find it kinda odd that all these people are having problems with these older mechanicly injected cummins motors now........i have a sneeking suspition that the new ulsd is finaly in 100% concentration now and its killing our poor p-pumps.:shrug:
please share what yall think on the subject.
MABB- members against big business
keep the internet free!!!!!!!!
floridaboy is offline
post #2 of 17 (permalink) Old 04-23-2008, 05:18 AM
I find that unlikely, the diesel is required to meet certain lubrication requirements and additives are used to meet those requirements. When they switched to the low sulfur diesel in the 90's the common problem was the rubber seals and fuel lines degrading. Vicron(sp) has been implemented in all 93 and newer trucks.
A question that comes to mind is what do you plan to do about it if your theory is correct? Add 2-stroke oil for the rest of the trucks life?
Thats my :2cents
Dual K20s is offline
post #3 of 17 (permalink) Old 04-23-2008, 06:57 PM
I thought most of the P7100 internals were lubed by oil? Not the fuel except maybe the DV's?
post #4 of 17 (permalink) Old 04-23-2008, 07:24 PM
Yes the bottom part is but the "top" is lubed by fuel, like the plungers, dvs, and maybe some other stuff
post #5 of 17 (permalink) Old 04-24-2008, 01:52 AM Thread Starter
gone fishin!
i just think that these trucks with low miles ad are now being driven more and more are suffering with the new fuel.......my little thery is that these pumps are not as worn in as one with 200,000 miles and have closer tolerences than a wore in one. i think the ulsd witch has less sulfer witch is a key lubercant in high pressure fuel pumps, is playing hell on these tight tolerences and causing failers....... just my little brain storm
post #6 of 17 (permalink) Old 04-24-2008, 01:57 AM Thread Starter
gone fishin!
my solution is bio diesel... i love this stuff, i get better gas milage, more power, lower egt's and less injector rattle. deffinatly a notable difference.
post #7 of 17 (permalink) Old 04-25-2008, 02:49 PM
2nd Gen Guru
Mopar1973Man's Avatar
The other problem is that if the delivery truck doesn't remember to put his lubrucant package in before loading with fuel then the HFRR value can be as high as 700-900 HFRR which outside the standards by a long shot. US Gov't standard is less than 520 HFRR... US manufactures suggest less than 460 HFRR which todays fuel doesn't even meet. Then to make the brain hurt more... The old LSD (500 ppm) was about 300-350 HFR for an average. So yeas todays fuel is causing more wear...
True Bio-Diesel is the #1 for fuel lubricity. But some of us don't have local acces to it. So if you want to protect your pump try 2 cycle oil when you don't have BIO handy... :Thumbup:
Mopar1973Man is offline
post #8 of 17 (permalink) Old 04-25-2008, 08:37 PM
check out the alternative fuels section in these forums. theres a wealth of info on additives and hffr values along with graphs and such. that should answer anyones questions.its already been covered on at least 5-8 pages under a couple different threads. try a search on 2 cycle oil.
97 Dodge 4x4 x-cab.206,000 mi. 4.10s. 5 speed. 330 bosch marines. pump at 16*advanced. boost at 35#s. AFE 4in, Turbo back, Magnaflow. Boost guage and pre turbo pyrometer. LuK Pro Gold Clutch.
Ziggy is offline
post #9 of 17 (permalink) Old 04-27-2008, 12:32 AM
Diesel Mafia #67
blackcloudCTD95's Avatar
Its mostly lubed by oil.. ever do a gov spring change? or fuel plate? take a peek under the intake shelf you will see a 90* fitting with a steel braded line going to it.. thats oil supply.. now trying to take one of those off.. GOOD LUCK!!!!! wrenches will be throw and curse words will be spoken!
Jordan
blackcloudCTD95 is offline
post #10 of 17 (permalink) Old 04-27-2008, 12:41 AM
:laffup
