best price on piston/rod - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 3AE F350, this thread has received 3 replies and been viewed 839 times.
post #1 of 4 (permalink) Old 01-10-2010, 07:58 PM Thread Starter
I need a piston a con rod for a '96 with 170,000 miles. I'm having trouble finding parts from somewhere other than Chrystler. Also, what else should I do while I'm in this deep into the engine? Initial problem was a knock from the wrist pin in #3 cylinder. Everything else seems good. Thanks for all the help.
3AE F350 is offline
post #2 of 4 (permalink) Old 01-10-2010, 09:53 PM
Contact Cummins they will make you a better price than Dodge.
While you have the head off you may want to O ring the head or add head studs, or main studs. It will just depend on how much HP you want.
later is offline
post #3 of 4 (permalink) Old 01-10-2010, 10:24 PM
Other things to inspect, rotate the motor and inspect the cam. I would do a bearing roll in, better safe than sorry. Blow in the oil galley and be sure the piston cooling galley, and nozzle are clear.
Johnp3 is offline
post #4 of 4 (permalink) Old 01-10-2010, 11:32 PM
gone fishin!
strip it down and hot tank everything!!!!!! i have built at least 8 of these motors and i have always found pluged skirt coolers and other oil passages......just bust it down and do it right.....also buy a rebuild kit for like $500 and do new rings and everything
MABB- members against big business
keep the internet free!!!!!!!!
floridaboy is offline
piston/injector? JakeDiesel Common Rail 3 02-16-2009 12:11 PM
piston above the dack? jap901 7.3L and 6.9 IDI (Pre 1994) 3 04-20-2008 01:45 PM
cracked piston f350bart 2003-2007 6.0L Power Stroke 6 08-09-2007 02:50 AM
466 Piston cooling nevrenufhp Medium and Heavy Duty 2 03-17-2007 04:48 PM
Piston Discussion Dieselson Duramax 2001-2004 (LB7) 0 11-30-2006 11:28 PM
