Dual battery bank install - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by justdoug, this thread has received 2 replies and been viewed 3366 times.
post #1 of 3 (permalink) Old 09-09-2010, 06:00 PM Thread Starter
justdoug's Avatar
If anyone is considering splitting up batteries,like I just did(3 for starting,1 deep cycle for all sleeper accessories) may i suggest a Shure-Power battery separator. I thought i needed a battery isolator but was schooled on why this separator is a better way to go. I won't bore you with all the technical details,just wanted to say it is as easy to install as i was told-very clean all connections inside battery box. The part# is 1315-200 (200amp rated). If anyone has additional ?'s i'll try my best to answer. Good Truckin'!
justdoug is offline
post #2 of 3 (permalink) Old 11-19-2011, 12:55 AM
O'Skool Member
Red Diesel's Avatar
How's the one deep cycle working for ya? Is one good or do ya wish you had 2 or 3?
I'm fixin to pick up a junkyard battery box. I was thinking three batteries for off key use. I use a mattress heater and electric blanky in winter and these drain my 3 starting batteries to fearful situation in the cold morning. I have my gen to charge batts but if the gen don't start...
Add in the interior lights, computer, etc. and 3 deep cycles sound good to me.
Red Diesel is offline
post #3 of 3 (permalink) Old 11-19-2011, 01:39 AM
Freightliner tried it using a solinoid that separated the deep cycle battery from the system when it was shut down. The deep cycle powered certain systems in the cab only. The deep cycle battery was killed, after a very short time, The repair was to remove the deep cycle battery and solinoid set up also remove the diode power separator in the Cab. Most of these were 4 battery systems, and the three battery set-ups were changed to fours.
It did not work, for Freightliner. Good luck!
Johnp3 is offline
Topgunz Dual stabalizer install Hollywood 2008-2010 Body & Suspension 11 10-18-2009 05:25 PM
bank intercooler piping(with a stock style intercooler) install question Jjona5 1994-2003 7.3L Chips & Tuners Forum 1 09-13-2009 12:46 PM
Battery cable install help JoeBob1901 1994-2003 7.3L Power Stroke 1 01-31-2008 11:56 PM
Dual Battery Questions Strokerin General Ford Truck and Excursion 4 11-08-2007 01:53 AM
Battery light and Dual Alternators? fordt 2003-2007 6.0L Power Stroke 2 09-08-2005 11:08 PM
