Cleaning Small Electrical Connectors Made Easy - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by terry_g, this thread has received 0 replies and been viewed 1553 times.
 1Likes
  • 1 Post By terry_g
post #1 of 1 (permalink) Old 08-16-2015, 01:22 PM Thread Starter
I thought I would share and maybe save a few others some frustration.
I do a lot of electrical and electronic troubleshooting mostly on trucks.
Corroded and dirty pins in connectors can be a pain to clean.
Some are small and easily damaged and their location can make them hard to replace.
I was recently dealing with an electrical problem that I tracked
down to a dirty and corroded connector. The seal was missing and
over time dirt and water had got in. Looking at the connectors I thought
where could I get a tiny file to clean the mating surfaces? On my way back
to my tool box I walked past the oxy-acetylene torch and there they were.
A set of tip cleaners in the perfect range of sizes.
The ends had to be trimmed as the serrations don't start at the end of the cleaner.
Make sure to use a cleaner that is smaller than it's mating connector so the
connector doesn't get distorted or stretched.
I have used them several times now with success.
Terry
dbennett48 likes this.
terry_g is offline
The Following 5 Users Say Thank You to terry_g For this addition to TDG:
379Longhood (08-16-2015), burkeftm (08-16-2015), dbennett48 (08-18-2015), DieselDave1 (08-17-2015), w9l (08-17-2015)
Bed slides: easy load - easy unload carid Work Truck Discussions 0 06-22-2015 02:17 PM
Injector connectors bismic 2003-2007 6.0L Power Stroke 8 02-07-2013 02:53 PM
Waterproof Connectors..Where to buy?? Steakman Duramax 2006-2007(LBZ & LLY) 2 02-07-2010 05:49 PM
Connectors for fuel bowl dayusex 2003-2007 6.0L Power Stroke 6 07-03-2009 09:40 PM
EGR Delete Made Easy by QUICKSHIP QU1CKSH1P 2003-2007 6.0L Power Stroke 86 05-05-2008 08:42 PM
