Cummins cpl 676 rebuild - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Cummins5.9r, this thread has received 0 replies and been viewed 1063 times.
post #1 of 1 (permalink) Old 11-24-2016, 01:08 PM Thread Starter
Okay so I need some help I'm rebuilding my cpl 796 back to a cpl 676 and swapping the cam now and am trying to get this motor to the 700 or 750 range now I have a few questions along the way
First I'll just tell you what I plan on doing, I'm swapping from the low flow cooling system and the water to air cooler and putting a n14 intake on instead and a CAC
I've talked to a really nice and help guy about the fuel part from diesel control in Ohio I think it's is and I believe we are going to do a set of injectors in the 250cc range and fuel pressure somewhere in the 250 to 300 range and run a hx60 or equivalent borgs turbo
Now my question is timing where do you guys thing would be a good place to set the timing to and how would I go about doing IE. do I need a different offset woodruff for the cam or will I get enough out of the follower gaskets.
And this will be a working truck in Illinois so it won't be running up any big mountains. thanks in advance
for the help
Cummins5.9r is offline
Cummins cpl 676 rebuild Cummins5.9r MD and HD - Modification Instructions, Product Installs and Tech Articles 0 11-24-2016 12:54 PM
Cpl help for cummins ntc/nte 855 erf Medium and Heavy Duty 2 09-17-2012 07:37 AM
Cummins CPL 324 Big Cam 400 specs? kblackav8or Medium and Heavy Duty 9 06-12-2012 10:58 PM
Cummins CPL 1210 N-14 Problem 9200IH Medium and Heavy Duty 7 01-30-2011 01:01 PM
found cummins CPL 1551 190hp w/p7100 rustyrelic 5.9L Cummins 12 Valve (1994-1998.5) 7 07-31-2007 01:29 AM
