Speedo dip switch how-to for IH trucks - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by tmleafs, this thread has received 4 replies and been viewed 11683 times.
post #1 of 5 (permalink) Old 04-27-2010, 12:48 AM Thread Starter
Complete How To Set Speedo
Since there is really nothing on the net about how to set the speedo, here it goes.
My specific speedo was factory set with all switches on 0 (including the last one, as mine is in kms, Canada eh?)
Next to the switches is the factory setting sticker. Here you will notice that along with the 10 positions for the speedo, but also the settings for the rest of switch 2. What i have learned is that on switch 2, numbers 4-6 switches is for teeth/rev. At first i was not sure what this was for. Basically, if you put in a custom setting for pulses/mile, you HAVE to have these switches to the correct factory position, which in my case is 4=0, 5=1 and 6=1. If you dont flip these switches, your speedo will NOT work as well as the rpm will NOT work. Also, if you dont flip the correct ones, rpm may not work at all or show the incorrect rpm's.
Here is the calculation i used:
I measured the tire diameter from concrete up. Get as accurate of a reading as you can get. My 10r22.5 are 39.5 inches.
Calculate circumference which is 39.5 * 3.14 = 124.03 (3.14 is a constant for all)
Calculate circumference in feet 124.03 / 12 = 10.3358 feet.
Calculate total revs/mile at the tire 5280 / 10.3358 = 510.8458. (5280 feet per mile is also a constant for all)
Calculate pulses/mile at the drive shaft 510.8458 * 4.44 (axle ratio) = 2268
Cross reference that with the chart for the dip switch settings. Use this as a starting point. If your speedo is measuring too fast, try a higher number like 2300, and if the speedo is measuring too slow, try 2200 as a reference point.
Name:	factory settings.jpg
ID:	25943   Click image for larger version
Name:	factory sticker.jpg
ID:	25944   Click image for larger version
Name:	new settings.jpg
ID:	25945   Click image for larger version
Name:	1189-1301, 1527-1638.jpg
ID:	25946   Click image for larger version
Name:	1302-1413, 1639-1751.jpg
tmleafs is offline
post #2 of 5 (permalink) Old 04-27-2010, 12:51 AM Thread Starter
Other pulses/mile chart, if you need other pages, i can post them.
Name:	1707-1188, 1414-1526.jpg
ID:	25948   Click image for larger version
Name:	1752-1863, 2089-2201.jpg
ID:	25949   Click image for larger version
Name:	1864-1976, 2202-2313.jpg
ID:	25950   Click image for larger version
Name:	1977-2088, 2314-2426.jpg
tmleafs is offline
post #3 of 5 (permalink) Old 04-30-2010, 12:37 AM Thread Starter
Thumbs up
Doh!!!!!
Just figured somethin out today. After calibrating speedo, i figured since my truck is canadian, that the default setting for the odometer would be kms. Not so my friends, default on the switch is mph. On my cluster, the last switch must be flipped to 1 to go to kms.
Just a note, hope it helps someone.
tmleafs is offline
post #4 of 5 (permalink) Old 05-14-2010, 01:10 PM
83Jim's Avatar
Thumbs up Well done...
looks like a good candidate for a "Sticky".
1992 International 4700 DTA360 dump truck, Spicer ESO66-7B (6+1) transmission w M210-T (2 speed) rear axle
1995 Dodge Cummins 2500 Laramie XLT 4x4 5 sp
83Jim is offline
post #5 of 5 (permalink) Old 09-18-2010, 02:40 AM
379Longhood's Avatar
Nice info , I thought that I could add that when flipping the switches to on they dont always make contact, especially when the cluster is a little old, so it is worth while to check them with a multi meter before putting the dash back in a little penitrating oil helps here
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline
No Speedo 83RTS GM Transmissions 1 07-29-2012 03:09 AM
speedo??? Lil Boosty 2003-2007 6.0L Power Stroke 8 10-27-2009 12:14 PM
No Speedo - ABS light AllOut0606 1994-2003 7.3L Power Stroke 17 08-01-2007 03:27 AM
Need speedo help on 07 F 250 firedude167 2003-2007 6.0L Power Stroke 8 07-06-2007 09:22 PM
Need to correct speedo worktruck 2003-2007 6.0L Power Stroke 7 05-23-2006 01:53 AM
