Tire Pressure VS. Temperature - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by merlin5577, this thread has received 9 replies and been viewed 3388 times.
post #1 of 10 (permalink) Old 12-28-2008, 07:22 PM Thread Starter
Gone Fishin...
merlin5577's Avatar
Post Tire Pressure VS. Temperature
I have been reading up on how air temperature can effect tire pressure and decided to try my own experiment. Starting a little over a month ago I set the tire pressures of my trucks with the air temperature at 60*F. I randomly checked the tire pressures on different days with different temperatures. After checking the pressure with a digital gauge. I then reset the pressures back to the original settings. To save time I rounded the pressures to the nearest whole number. Here is what I found;
Silverado; Baseline Setting 80psi
Air temperature 40*F
Pressures; LF 76, RF 75, RR 78, LR 78
Air temperature 21*F
Pressures; LF 72, RF 72, RR 77, LR 77
Air temperature 36*F
Pressures; LF 81, RF 82, RR 84, LR 83
Air temperature 50*F
Pressures; LF 43**, RF 82, RR 87, LR 86
Suburban; Baseline setting 40psi
Pressures; LF 37, RF 37, RR 39, LR 39
Pressures; LF 35, RF 34, RR 38, LR 38
Pressures; LF 40, RF 42, RR 42, LR 44
Pressures; LF 42, RF 42, RR 44, LR 45
** Nail was found in tire. Had slow leak so data is corrupt.
Conclusion; across the board, the rear tires generally lost less pressure. This I believe is because of the weight of the engine in the front pushing down. Also note the higher pressure settings (Silverado) where generally more affected by changes in temperature.
I hope everyone can appreciate this. Please everyone, take a few minutes and check your tires regularly. Be safe out there.
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
The Following User Says Thank You to merlin5577 For this addition to TDG:
bear1 (06-07-2013)
post #2 of 10 (permalink) Old 12-28-2008, 07:34 PM
bmoeller's Avatar
I usually see nearly a 10 psi drop from summer to winter on the big trucks.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 10 (permalink) Old 12-28-2008, 10:47 PM
Cooper443irty's Avatar
This past thanksgiving week I had new tires put on my truck. So far I have had to add air twice, about a month’s time. I too have noticed the front took more air then the rear. The past 5 years I had a different tuck with nitrogen in the tires, only had to have nitrogen added once. Now I wish I had nitrogen in the new tires, and I use to think the advantages of nitrogen were myths.
Cooper443irty is offline
post #4 of 10 (permalink) Old 12-29-2008, 06:11 PM
O2ShootTheJ's Avatar
isn't this just gay- lussacs law? P1 / T1 = P2 / T2
Singles Club #222
December 2008 TOTM
Riding High Club #2
2008 Truck of the Year
Ridin' Dirty Club #2
Big Thanks to:
O2ShootTheJ is offline
post #5 of 10 (permalink) Old 12-30-2008, 01:15 AM
Superdutytd's Avatar
Images: 3
I've heard that nitrogen stuff works pretty good...?
2008 Red CCSB 6.4 Auto Lariat.
Stock 20's wrapped in 35x12.50R20 Toyo MT's, 3.73 gears, Nav, Backup Cam, Tailgate step, Upfitters, etc.
Mods: AFE Intake, Line-X, 20% Tint, Clear Bra, Husky Mats, Smoked Recon Mirror markers/3rd brake light, Bushwacker Pocket style flares w/ mud flaps + an aluminum Rapid Hitch (one of the best investments!)
Feel free to PM with any questions about any of my mods.
SRW Club #55
American Club #55
Last road trip-567 miles @ 20.7 mpg @ 67mpg average speed.
Superdutytd is offline
post #6 of 10 (permalink) Old 12-30-2008, 06:02 AM Thread Starter
Gone Fishin...
merlin5577's Avatar
On both my trucks, when the tires where first put on, where filled with straight Nitrogen and from my experiences made no differences in how much or often I had to adjust the tire pressures. Since everyones circumstances are different, your results may differ.
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
post #7 of 10 (permalink) Old 12-30-2008, 12:00 PM
Whipersnapper
battle cattle's Avatar
Time gone from Iraq!
Send a message via AIM to battle cattle Send a message via MSN to battle cattle Send a message via Skype™ to battle cattle
In my M3 I run pure nitrogen (not mix) and my pressures stay constant +-2 degrees even on the track as my tires warm up. Only problem I have is how expensive it is because they have to pull a vacuum inside the tire then put the in nitrogen.
I think the tech side is that the Nitrogen molecules are inert gas which isn't AS effected by heat or lack of heat.
2008 F350 DRW SB Black/Black (Spartan Tuned) SOLD
2006 BMW M3 Black/Black (Stock)
Angel Bunnie: though Russifer is a pretty little guy
Dually Club #60
battle cattle is offline
post #8 of 10 (permalink) Old 12-31-2008, 12:43 AM Thread Starter
Gone Fishin...
merlin5577's Avatar
The two things I also didnt consider are atmospheric pressure and humidity. They both can have an effect on the contraction and expansion of air. If I ever repeat the experiment, I will measure those factors as well.
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
post #9 of 10 (permalink) Old 01-04-2009, 05:44 AM
********* and Mafia #90
Bcarriveau's Avatar
That it does 99% big offroad rigs use it so they dont have to mess with the psi all the time in diff temps.
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #10 of 10 (permalink) Old 01-14-2009, 07:18 AM
4play's Avatar
pure nitrogen is better in many ways for tires. but untill i have to start paying for the air in my tires i will not consider nitrogen. by the way the earths atmosphere consists of approx 78% nitrogen. so i do put mostly nitrogen in my tires.
4play is offline
help fuel pressure!! covey88 5.9L Cummins 12 Valve (1994-1998.5) 15 12-30-2008 01:58 PM
LB7 01 Temperature Versus Resistance ripmf666 GM Spec Info 0 12-28-2008 09:37 AM
01-08 Use of Room Temperature Vulcanizing (RTV) and Anaerobic Sealant ripmf666 GM Spec Info 0 12-27-2008 12:23 AM
need tire help SSpeeDEMONSS The Parking Lot 7 12-24-2008 04:01 PM
Fuel pressure question 350FORD 2003-2007 6.0L Power Stroke 6 12-24-2008 03:10 AM
