Glow Plugs - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by korr1972, this thread has received 3 replies and been viewed 2466 times.
post #1 of 4 (permalink) Old 11-23-2007, 02:53 PM Thread Starter
Glow Plugs
:smoke how do you know when to replace and do you have to replace all of them at the same time??:smoke
korr1972 is offline
post #2 of 4 (permalink) Old 11-25-2007, 08:30 AM
1996 StrokerKid's Avatar
what ive heard is just change em all out at the same time. better to make em all strong then to leave a few weak links in there.
1996 F-350 LB CC 4 in. lift 35 in. BFG AT's Go Rhino Grill Gaurd, Stancor GPR.
"Id rather be stroked than rammed!"
1996 StrokerKid is offline
post #3 of 4 (permalink) Old 11-25-2007, 10:44 AM
You'll notice the engine getting harder & harder to start and will start seeing more & more white smoke as the plugs fail one by one. If you're going to go to the effort to take off the valve covers to replace one, it's a heck of a lot easier to replace them all and be done with it. The one thing to be very careful of is that you don't break off a plug in the head.
worm drowner is offline
post #4 of 4 (permalink) Old 11-25-2007, 04:08 PM
Super Moderator
John_G's Avatar
If you have an IDI (6.2/6.5L, 6.9/7.3L) then it *may* be wise to replace all 8 if you find a bad one IF they have all been in there for a couple of years.
With the PSDs, I have only replaced two or three GPs since 1994, and only one was not murdered by a bad IDM harness (they will NOT tolerate 115V), it was just bad - had an open circuit. So with the PSDs, I am very much in the "fix as fail" camp.
With the IDI engines, it depends also on the brand of GPs you have. If, for example, you have a Ford/IH IDI engine, and find non-OEM GPs in it, get rid of them ALL the first time and use OEM replacements, then fix-as fail.
I vote for LIBERTY!
John_G is offline
