f350/250 diesel: 12v Engine running "feed" - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bushpilot, this thread has received 2 replies and been viewed 2439 times.
post #1 of 3 (permalink) Old 03-07-2010, 02:48 PM Thread Starter
bushpilot's Avatar
Im trying to find a 12v(+) "engine running" feed for a battery
isolator relay.
I picked up one of the wires off the alternator, but when
i use that signal the alternator light (on the dash turns on).
Can anyone recommend what wire to use ?
Don R.
Truck Audio,
bushpilot is offline
post #2 of 3 (permalink) Old 03-10-2010, 01:15 AM
isolator relay.
We use the "P" lead (or terminal) with a resistor in series with the relay coil. This limits the current draw and maintains sufficient voltage for operation of a tachometer. Be mindful this is AC voltage. Some relays may require a diode and a LC circuit for proper operation.
Our system controls current to a trailer feed and includes a current limiter.
AGFR is offline
post #3 of 3 (permalink) Old 03-10-2010, 01:46 PM
isolator relay.
My apologies. I realized after posting my above suggestion you probably have a 6G alternator installed which doesn't have a "P" or phase terminal. If you are so inclined you can connect a lead to one of the stator/diode connections and use that signal to operate a relay, i. e. Hella Type 4RD or Bosch equivalent. We've found this signal is about 7 V rms (half wave) and will activate the relay without any rectification or filtering. There are some other methods, but this approach is the simplest.
AGFR is offline
Tw...2003 f350 "bamf" fummins 03f3507.3 Ford Parts 4 12-27-2009 09:03 PM
The "New Diesel Emissions" prevent the use of a "Jacobs" (jake brake) HARLEY6LF250SDU General Diesel 4 01-17-2009 02:53 PM
Anyone running 35" or 37" tires with 4.10 or 4.30 gears? sbechtold 2008-2010 6.4L Power Stroke 12 01-25-2008 01:20 PM
05 F350 S/C 8" Lift Custom Paint 37"/20" biavaperformance Whats Been Sold 0 06-22-2006 09:11 PM
NBA Headlines Ford: A new No. 1 contender<img src="http://espn.go.com/i/in.gif" width="11" height="11" hspace=4 border="0" alt="Insider"> RSS Feeder The Parking Lot 0 06-09-2006 07:00 AM
