Stereo Problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by imported_99powerstroke, this thread has received 2 replies and been viewed 644 times.
post #1 of 3 (permalink) Old 01-28-2007, 04:40 AM Thread Starter
Stereo Problem
Well I bought a G Logic box w/ a 10" Lanzar sub, Rockford Punch 600 watt amp and hooked it all up. Well I wanted to keep my stock radio so I went to Best Buy and got the FM module thing that allows you to hook up the RCA cables. It says to use the rear speaker wires and hook them up accordingly to the FM Module. I do that get power to the amp and have everything ready to go. Turn on the radio and the sub kinda is going in and out, and to me it seems like a wiring problem w/ that damn FM Module thing, but it is hooked up right according to the directions :deal: Any ideas??? :shrug:
Thanks
David
imported_99powerstroke is offline
post #2 of 3 (permalink) Old 01-30-2007, 12:44 PM
cookiemonsterblue
my stereo used one of those for quite a while however have you considered using the high inputs in your amp instead of the rca(this is using the speaker wires instead of rca)? also have you checked to see if the conections on the sub are loose? mine vibrated loose and i thought my amp was screwed when i took it to best buy they just tightened the connectors with a pair of pliers for a tighter fit.
cookiemonsterblue is offline
post #3 of 3 (permalink) Old 01-30-2007, 12:45 PM
cookiemonsterblue
sorry vibrated loose inside my speaker enclosure
