Bypassing parking brake to watch dvd's on my flip out while driving - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by imported_99powerstroke, this thread has received 10 replies and been viewed 2010 times.
post #1 of 11 (permalink) Old 11-22-2007, 04:17 AM Thread Starter
I am trying to figure out how to bypass my parking brake so I can watch dvd's in my truck on my flip out while moving. THere is a wire that is suppose to be hooked up to my parking brake and w/out that hooked up the screen wont come up.."says brake must be applied" is there anyway around this?
Thanks
imported_99powerstroke is offline
post #2 of 11 (permalink) Old 11-22-2007, 07:05 AM
TDG Mafia Member #82
Check around the brake pedal there should be a sensor most of the time its just a push sensor that can be pushed in and taped up...........
SCT tuned by Dfuser
RBP 4" Turbo Back Straight pipe
Airaid Cold Air
6in Superlift
2in Blocks
39.5 Iroks on 20in. Monsters
Bruiser6.0 is offline
post #3 of 11 (permalink) Old 11-23-2007, 03:36 PM
Let us know when you are on the road watching DVD's, OK.
cjensen91910 is offline
post #4 of 11 (permalink) Old 11-23-2007, 04:26 PM
just click the parking brake down one click and it shouldnt drag on the brakes at all but the light will come on allowing you to watch dvd's while moving
DBogo is offline
post #5 of 11 (permalink) Old 11-23-2007, 11:11 PM Thread Starter
its for passengers when we go on trips.. but thanks for the useless input...
post #6 of 11 (permalink) Old 11-24-2007, 02:37 PM
usually you just ground the wire to a good ground. Problem solved.
Jakkle5 is offline
post #7 of 11 (permalink) Old 11-24-2007, 04:36 PM Thread Starter
cant ground the wire only as it has a parking brake sequence you have to go through to clear the screen... so i just used a toggle switch and hooked the parking brake wire up to it and grounded it, then used the toggle switch as the parking brake to go through the sequence and clear the screen... Doing this also allows me to turn it off if someone else drives my truck and then thy cant watch dvd's at all...lol
post #8 of 11 (permalink) Old 11-24-2007, 05:45 PM
I be Architect'n
Sometimes you only have to ground the VSS (Variable Speed Sensor) wire and the parking brake. Sometimes you have to do a little more. My Pioneer D3 required a grounding of the VSS, PB and the service pin.
Google search for your model + bypass and I'm sure someone, somewhere has put it on the interwebs.
2K3 EXCURSION 7.3L 4x4 EDDIE BAUER 107K miles as of 06-13-07
AFE Stage II / 4" MBRP exhaust / DP-Tuner F5 (Stock, 60hp Tow, 80hp Econo, 120hp race & High Idle) / Quadzilla Commander/ATS Housing
Running homebrewed BioDiesel and custom SVO kit for 70k miles.:Thumbup:
Misc. Mods: ZooDad/By-Pass Oil Filter/203* T-Stat/Coolant Filter/HPX/CCV Reroute/Tranny Filter/Foil Delete/Stereo Stuff/ITP Reg Return/Non-EBPV Pedistal and Exhaust Housing/Adjustable Waste Gate Controller/
"If you love your motorcycle, set it free. If it comes back to you it was probably a high-side."
I'LL TRY TO KEEP UP, BUT THE EXCURSION IS A BIG GIRL AND BIG GIRLS DON'T LIKE TO MOVE FAST.
6_Myles is offline
post #9 of 11 (permalink) Old 11-25-2007, 01:44 AM
Superstroker's Avatar
I had a dvd video in my truck and all i did was ground it to a good ground and that fixed the parking brake BS.
1999 24v ext cab quad cab long bed Laramie 4x4 : 155k miles, straight piped, Edge Juice w/ Attitude, "Dr Evil" trans rated for 800hp with 2500 stall gear driven TC, airdog 100, 2" leveling kit 33" mastercrafts.
Avatar is before I bought it of course. new pic coming soon
SOLD: 2006 F250 6.0 EXT CAB SBSCT by DFUSER,INNOVATIVE,: 2003 turbo :4inch cool duals and 6inch tips: HP Intake elbow: ARP STUDS: Diprocol Boost, Pyro, Trans, Fuel Pressure guage in quad pod: Isspro EOT guage in dash bezel: HID 6000k Headlights:305/40r22 on ProComp Extreme black and aluminum wheels: 2008 Mirrors,Tailgate, taillights and bumper: Sir Michaels Roll Pan: Billet fuel and Oil Caps:Billet grille: Billet tow hooks:Kenwood Double Din: Acetoned badges:
Superstroker is offline
post #10 of 11 (permalink) Old 01-30-2008, 01:44 PM
I grounded mine as well. I did have to search the web and find a bypass code to get past the parking brake sequence. I would rather have the toggle switch set-up like you have though. In AZ it's a hefty fine for having video playing while driving. With the toggle you can switch it off in that case and they would never no the difference.
abq954 is offline
