Ladder Bar Length???? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bigdraft, this thread has received 12 replies and been viewed 1713 times.
post #1 of 13 (permalink) Old 04-27-2008, 02:28 PM Thread Starter
The Big Meanie
bigdraft's Avatar
Ok guys and gals......I'm thinking about having a set of ladder bars made for the Dodge instead of buying a set. Tossing the idea around.
Is longer better? I know some guys have them real long, and some are '''standard''' kength. Which is better? The rear of the Dodge bounces like crazy in sand, mud, snow....anytime I gotta get on the go pedal hard.
Thoughts...ideas?????
oopkevinoop
Boys Stroke It...Men RAM It
Dually Club Member
Farm Club Member
I Got A Named Bubba
In Progress...
FOREVER FARMS
What Is A Farm With No Barns?
bigdraft is offline
post #2 of 13 (permalink) Old 04-30-2008, 08:41 PM
BJS
the ladder bar should be long enough that it ends up roughly parallel to your driveshaft for optimum desirable suspension movement
BJS is offline
post #3 of 13 (permalink) Old 04-30-2008, 09:53 PM Thread Starter
The Big Meanie
bigdraft's Avatar
cool.....thanks!!!!!
oopkevinoop
Dually Club Member
Farm Club Member
I Got A Named Bubba
In Progress...
FOREVER FARMS
bigdraft is offline
post #4 of 13 (permalink) Old 04-30-2008, 11:55 PM
With that being said....would that be to transfer case or to a carrier bearing?
USAFdieselman is offline
post #5 of 13 (permalink) Old 04-30-2008, 11:56 PM Thread Starter
The Big Meanie
bigdraft's Avatar
yeah...good question there.........
oopkevinoop
Dually Club Member
Farm Club Member
I Got A Named Bubba
In Progress...
FOREVER FARMS
bigdraft is offline
post #6 of 13 (permalink) Old 05-02-2008, 01:11 PM
TNRGreene's Avatar
Mine are 60" from tube end to tube, plus heims. Mine follow the driveshaft angle. I have a 04 CC/SB GMC
Todd
04.5 K2500 GMC Black Puller
Video
03 K2500 Chevy Worker
Greene's Performance Diesel
Building winners since 2004
Home of:
~B & B Pulling Team
~2008 SFTP Street Diesel Champion- BLACKBALLED
~2008 SFTP Outlaw Diesel champion- FREIGHTTRAIN
~2009 FATC Street Diesel Champion- CODE RED
~2009 FATC Outlaw Diesel Champion- BLACKBALLED
United We Smoke
Run your truck, not your mouth ]
TNRGreene is offline
post #7 of 13 (permalink) Old 05-02-2008, 06:44 PM
BJS
If you have a carrier bearing then that's where it would go to.
Better phrased as parallel to the section of the driveshaft that attaches to the differential.
BJS is offline
post #8 of 13 (permalink) Old 02-02-2009, 08:40 PM
SSpeeDEMONSS's Avatar
NOT!
a "ladder bar", with 2 mounting points on axle should have a shackle on the frame mount. also, a ladder or "lift bar" should be shorter as it will be exerting the force upwards which would "lift" the the bed and apply downward force on the rear axle
a "traction bar", single axle mount and no shackle, should be longer. optimum mounting point for proper weight transfer would be at the balance point. the force from a "traction bar" is exerted forward onto the frame mount which "lifts" the front end and helps plant the rear.
you can make a "traction bar" shorter but it wont work as good. the same goes for making a ladder/"lift bar" longer.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #9 of 13 (permalink) Old 02-02-2009, 10:37 PM Thread Starter
The Big Meanie
bigdraft's Avatar
Allright....dammit guys, now ya'll got me all confused.........
The rear end of the Dodge jumps around like crazy when I get into snow, sand, mud....anything that makes me get on the go pedal....in 2 wheel or 4 wheel drive.....jumps around and shakes the whole dang truck.
Soooooo, what do I need?????
kevin
Dually Club Member
Farm Club Member
I Got A Named Bubba
In Progress...
FOREVER FARMS
bigdraft is offline
post #10 of 13 (permalink) Old 02-03-2009, 12:54 AM
kevin
you can use either or.
when you do make them tho just make sure they are built properly.
