Source for buying wire? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jvencius, this thread has received 6 replies and been viewed 741 times.
post #1 of 7 (permalink) Old 07-17-2009, 01:17 PM Thread Starter
Does anyone have a good mail-order/online source for quality automotive wire? I need to do a bunch of re-wiring for all the electrical doodads I've put in my truck but the craptastic wire RadioShack sells just won't cut it. I'd like to get a half-dozen colors or so, just to make tracing individual wires in a multi-wire bundle easier...
jvencius is offline
post #2 of 7 (permalink) Old 07-17-2009, 04:52 PM
FTG-05 is offline
post #3 of 7 (permalink) Old 07-18-2009, 04:20 AM
Any marine supply for the best, independent auto parts houses are usually good. For a better than average stock an electronic parts house - mouser.com or digikey.com
81 Isuzu /C223na, 5spd
keydl is offline
post #4 of 7 (permalink) Old 07-18-2009, 04:56 AM
dodgefarmer2's Avatar
know any electricians, when they pull wire in conduit there is usually plenty of extra wire all different colors.
08 dodge 3500 dually, quad cab, inferno red,6.7, 4x4, 6sp auto, rhino lined bed, b&w gooseneck turnover ball,full length fiberglass running boards (color matching),reese hitch.
MEMBER THE DUALLY CLUB #75
MEMBER THE AMERICAN CLUB #41
10,055,000.00 points approximately
dodgefarmer2 is offline
post #5 of 7 (permalink) Old 07-19-2009, 01:58 AM
The wire that is used for buildings is either solid or course strand. The correct wire for automotive is fine strand - it flexes a lot more before it breaks.
That said, I use the THHN for wiring that in NOT subject to movement, for anything crossing to the motor or unsupported, I use the real stuff. My favorite way to support is to tape the wire to the sheet metal and run a bead of caulk over the wire so it sticks both sides of the wire.
keydl
keydl is offline
dodgefarmer2 (07-19-2009)
post #6 of 7 (permalink) Old 07-19-2009, 11:08 AM
i've been using the wrong wire for almost 30 years without problems. i guess i'll know where to look when i do.
post #7 of 7 (permalink) Old 07-20-2009, 02:44 AM
I spent 4 years repairing radars for the Navy to learn their way.
I bought a bad news boat from the start of mass produced fiberglass that had a lot of the wiring replaced with solid wire. The stories are true, all that is needed to break a wire is approach, the first time that the same wire broke I salvaged the wire out of a scrap boat.
I have brought stuff home with extention cord for wire and watched a tractor that had a coil wire of 12 ga solid for a burned wire when the coil failed, the tractor was still going 14 years later when I lost track of it.
I have no clue why the wire on the boat failed where a simular piece on a tractor ran a long time as the vibration on a 4cyl tractor is more than a 6 cyl boat. Might be hours 6 to 8 hundred a year for the tractor and over 2500 for the boat.
keydl
keydl is offline
New radiator source worktruck Medium and Heavy Duty 2 03-06-2008 12:58 AM
6.0 Vibration- Unlikely source! imported_jonesie 2003-2007 6.0L Power Stroke 0 03-01-2008 04:58 PM
intercooler source? Taco XL 1994-2003 7.3L Power Stroke 5 11-07-2007 10:44 PM
Another engine source John_G Diesel Conversion 0 08-12-2007 05:45 PM
Switch 12V Source BlackSuperStroker33 2003-2007 6.0L Power Stroke 1 08-27-2005 07:13 AM
