oil cooler write up? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by harleystroker, this thread has received 4 replies and been viewed 1747 times.
post #1 of 5 (permalink) Old 08-14-2010, 03:28 PM Thread Starter
harleystroker's Avatar
Send a message via Yahoo to harleystroker
I'm going to tackle this once I get back home and want to know if there is a write up on it... I plan on making one but I could use one as a guide
04 Harley F250 c/c s/b: 06 headlights, 3'' rough county lift, Eagle 20's, 35'' tarragrapplers, 4'' turbo back magnaflow with cat/muffler delete, 6000k HID's, Recon line of fire/ mirror lights/3rd brake/&Tales,Studs/gaskets,Tuned SCT X3,STL strobe kit, Icon shocks,Dfuser Egr/ Egr cooler delete, 03 turbo
http://i135.photobucket.com/albums/q...04/sq_com4.gif
harleystroker is offline
post #2 of 5 (permalink) Old 08-14-2010, 05:29 PM
I can email you one if you pm me your email address.
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD BilletWaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
bismic is offline
post #3 of 5 (permalink) Old 08-15-2010, 02:17 PM
Curmudgeon
TooManyToys's Avatar
Oh, sure. I'm at the half way point of changing my oil cooler and NOW you have a write-up.
Jack -
Formerly FMTRVT, Manager of Vehicle Testing - Brakes
2003 F-350SC Lariat 4x4 6.0L Auto
Truck Modifications as below in Pictorials on Facebook. Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
TooManyToys is offline
The Following User Says Thank You to TooManyToys For this addition to TDG:
bismic (08-16-2010)
post #4 of 5 (permalink) Old 08-16-2010, 06:55 PM
Part of what I have is from you Jack (but you knew that!) and THANK YOU for it!
The rest is out of the Ford WSM manual + a tidbit of advice from some other knowledgeable folks.
I m seriously debating doing mine, since I am "on the edge" w/ the deltas.
Mark
bismic is offline
post #5 of 5 (permalink) Old 08-18-2010, 01:58 AM
Curmudgeon
I wasn't sure if you had something more descriptive.
Having just finished mine, the Ford service directions are very good step by step. I deviated here and there, and did a few other tasks as well.
Jack -
Write up on 08 conversion? JMS8800 General Ford Truck and Excursion 26 07-12-2010 02:03 PM
Where is the BB Mod or FPR Plug Write-up? justinlw 2003-2007 6.0L Power Stroke 1 05-15-2009 05:11 PM
who can write me f350bart 2003-2007 6.0 Tuner Forum 73 03-25-2009 02:12 PM
I did my write up.. blackcloudCTD95 5.9L Cummins 12 Valve (1994-1998.5) 11 08-19-2007 06:36 AM
