10 minute head lifting bracket - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by lenzhotrod, this thread has received 7 replies and been viewed 5111 times.
post #1 of 8 (permalink) Old 03-10-2014, 02:11 PM Thread Starter
Made one up in less than 10 minutes with supplies I had in my garage. Used 2" angle iron, 1 1/2" washer, and 4ea 1/4 long nuts. Used an old intake gasket as a template, and drilled out the long nuts with a 5/16 bit. After welding the washer I put it in a vice and bent it back at an angle. Works as well as factory Ford I have used in the past!!! Excuse the weld my mig is running out of gas.
lenzhotrod is offline
The Following 4 Users Say Thank You to lenzhotrod For this addition to TDG:
bismic (03-11-2014), harry6.0 (03-11-2014), MT Pockets (03-10-2014), Weld engineer (03-11-2014)
post #2 of 8 (permalink) Old 03-11-2014, 03:22 AM
Weld engineer's Avatar
The zinc and paint also increase your porosity levels and bead appearance. Sorry can't turn it off.
Where does this attach and would it work with the cab on? Just in case my studs one at a time experiment ever does fail.
Thanks!
Wes
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
post #3 of 8 (permalink) Old 03-11-2014, 03:43 AM Thread Starter
It attaches like the factory bracket, it bolts to the center of the head where the intake manifold bolts to the head. And yes it works with cab on, that's the only way I've ever removed heads. I will post the ford instructions when I get to my other computer. I have the Ford bracket at work but it was quicker to build one than it was to go back and get it. It worked just as good as the $150.00 Ford unit and most anyone could build it for less than two dollars! Weld, if that's your profession you could easily sell these for 20-25 dollars a piece.
The Following User Says Thank You to lenzhotrod For this addition to TDG:
post #4 of 8 (permalink) Old 03-11-2014, 04:07 AM Thread Starter
mounting
Here is how it mounts.
head bracket use.pdf
post #5 of 8 (permalink) Old 03-12-2014, 06:58 AM
Stuck in Commiefornia...
IdahoF350's Avatar
First, I did mine twice cab on, it's a hell of a lot more work than lifting the cab. Never again.
Second, the head is way down in there with the cab on, and while this bracket would be fine for cab off, cab on you're still going to need a good 12-16" length of chain and hook, and the head is going to fall funny and make wrestling the head in a challenge.
In the 26 years since I started turning wrenches for money, the hardest job I've ever done is a set of 6.0L head gaskets with the cab on. Never again. I'll do head gaskets on a 6.0L, but I'll lift the cab.
2000 Excursion XLT 4x4
IdahoF350 is offline
post #6 of 8 (permalink) Old 03-12-2014, 01:17 PM Thread Starter
Funny that you mentioned that. I was trying to think of some type of swivel at the lifting bracket and a 1/2" rod shaped like > to clear the overhang. I don't find it difficult with cab on because I always have a second set of hands operating the lift.
post #7 of 8 (permalink) Old 03-12-2014, 05:47 PM
IdahoF350's Avatar
The second set of hands to run the lift is the least of your worries. To do it cab on there is so much stuff in your way, like the AC box and the firewall. By the time you get everything out of your way, fight the stubborn up pipe bolts, and contend with all the other little things that are going to be in your way, pulling the engine or lifting the cab becomes a far less frustrating proposition than it sounds. If my truck had been an automatic, I would have pulled the engine the second time.
And if you use the rocker arm bolt locations to hold the head you'll be closer to the center of gravity of the head which will let the head hang in better balance and make it more maneuverable.
post #8 of 8 (permalink) Old 03-13-2014, 02:11 AM Thread Starter
I will agree with you on the up pipe bolts! Sometimes that seems to be the worst part of the job.
lifting points for 3406E cyl head SmoothTightKittyCAT Medium and Heavy Duty 18 03-01-2014 01:55 AM
Has anyone changed head-gaskets without lifting cab? jethrow 2003-2007 6.0L Power Stroke 25 04-29-2008 09:35 PM
Five Minute Management Course imported_Saftman The Parking Lot 5 09-10-2007 02:46 AM
Just want to take a minute...... BigWhiteSicksO The Parking Lot 3 07-04-2006 04:29 PM
Take a Minute crzycowboy The Parking Lot 7 06-26-2006 07:03 PM
