2 stroke oil - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by deereman39, this thread has received 10 replies and been viewed 1936 times.
post #1 of 11 (permalink) Old 04-01-2014, 05:15 AM Thread Starter
deereman39's Avatar
Question 2 stroke oil
Those using 2 stroke oil in fuel what amount are you using per gallon or tank full?
Thanks Ed
2005 F-250,XLT Extended Cab,2X4 6.0 363 CID DI V8 ENG.Born 03/05 Metalic silver
American Made in Jefferson County KY.
Torque Shift 5 speed Auto. 373 Gears.[Second Owner]
Refinements Are as follows.
ARP 250-402.PDF Head Studs [One at a time]
Blue spring kit
CCV Mod
EGR Cooler ["GONE"]
Fog Light Mod
Greas Zerk in Drive Line Slip Joint
Harpoon mod.
HFCM Valve #6E7Z-9C082-A
Injector Spools [Cleaned for Stiction]
Scangauge 2
Updated Stand Pipes & Dummy Plugs
XDP Coolant Filter Kit
Zoodad Mod
Updated STC Fitting
SCT tuning
Boob Man=Brotherhood of oil burners
2005 31' Cardinal 5er
Remember if you stop to think,Don't forget to start again
Please Support Our Troops,With Out Them We Would Not Have This.
deereman39 is offline
post #2 of 11 (permalink) Old 04-01-2014, 05:51 AM
1 oz per gallon
2006, F-350, 6.0, 4x4, Lariat, crew cab, long bed with Leer 180 shell
MagnaFlow 4" turbo back exhaust system
DC Power Engineering 190 amp alternator
Firestone 2400 Ride-Rite air bags
Ranch Hand Legend grill guard
Isspro four gauge pillar set
HID Bi-Xenon headlights
HFCM water drain plug
Fumoto oil drain valve
Accufab intake elbow
Bilstein 5100 shocks
Ctek batteries tender
DFuser coolant filter
Rotella Ultra ELC
Blue Spring mod
Bilstein stabilizer
ScanGauge II
Up-idle mod
Zoodad
Archoil (AR9100, AR6200) & PRI-D & PRI-G Dealer
http://www.johnfjensen.com
snowgoose is offline
The Following User Says Thank You to snowgoose For this addition to TDG:
deereman39 (04-01-2014)
post #3 of 11 (permalink) Old 04-01-2014, 01:12 PM
I used 1/2 oz. per gallon while running Jet A.
lenzhotrod is offline
The Following User Says Thank You to lenzhotrod For this addition to TDG:
post #4 of 11 (permalink) Old 04-04-2014, 07:20 PM
Eddy
Eddy's Avatar
Ive been using 1 oz per gallon also. SuperTech from walmart. I use the ashless version. TC-W3. buy it in the gallon. It's cheaper that way. On a side note. I have increased my mix to 1.25 to 1.5 oz per gallon. Still doing some reading but, if our regular mix for lawn mowers, chain saws etc.... is 1oz per gallon for proper lubrication. I would think a little more would be needed looking at the size difference between our injectors and quantity 8 and a lawn mower?? Any feedback is welcomed on my theory.
2006 F-350 CC, LB, SRW, Lariet 5sp Auto. Burgandy Exterior with Tan Leather Interior. 4" Exhaust turbo back. Studded with ARP bolts 6/15/2013 with OEM Gaskets, SCT Custom tunes by Kem Performance, Isspro gauges, Blue spring kit upgrade. Coolant filter, Afe pro guard 7 stage 2 air intake.
Eddy is offline
The Following User Says Thank You to Eddy For this addition to TDG:
deereman39 (04-05-2014)
post #5 of 11 (permalink) Old 04-04-2014, 07:33 PM
Eddy
Eddy's Avatar
Double post. Deleted.
Eddy is offline
post #6 of 11 (permalink) Old 04-11-2014, 11:51 PM
nitrogen's Avatar
you could probably run 50/50 without hurting anything besides your wallet. The intent is to increase the lubricity. The fuel may not be a super lubricant, but it is not without some level of lubricity. Therefore all you really need is to supplement it a bit. The 1 oz/gal, was a result of lubricity tests in the lab that showed the improvement to be well above the fuel system manufacturers specs
Canadian Club #31
nitrogen is offline
The Following User Says Thank You to nitrogen For this addition to TDG:
deereman39 (04-18-2014)
post #7 of 11 (permalink) Old 04-20-2014, 04:27 PM
harry6.0's Avatar
Heres some thoughts on the use of 2 cycle tcw3 outboard motor oils...
2 cycle tcw3 outboard motor oils is what some use as a lubricity enhancer for diesel fuel.
These oils have a typical flash point of 200-300F, but that only means they will vaporize at those temps and are available to ignite if they have an ignition source...such as a spark plug...which our diesels do not have. Our diesel engines rely on auto ignition by compression and heat.
So, "auto ignition" temp specs is what you want to see in 2 cycle oil to make sure it is burning thoroughly...which in most tcw3 rated mineral based oils is between 599-608F.
Typical no.2 diesel fuel "auto ignition" temp is between 489-545F.
Our diesel engines produce more than enough actual combustion temps to burn off the ashless cleaner burning tcw3 2 cycle mineral oils, especially in the lean 200:1 averages of .5oz to 1 gallon. Actual combustion temps in the cylinders can exceed 2500F. Egt's are not combustion temps, but are cooled exhaust temps after the combustion process, which are typically 600-1200F in our motors.
Some no.2 diesel fuels like those sold in California, now require a minimum of 2-5% bio diesel in the fuel sold at the pump...so with that you are getting plenty of lubricity already.
Problem in my area is, one never knows what your getting at the pump.
Using .5 oz of tcw3 per gal in cold climate regions due to all the solvents-anti gel additives used in winter blends might be a good idea.
Harry
harry6.0 is offline
Eddy (04-21-2014)
post #8 of 11 (permalink) Old 04-20-2014, 05:46 PM
I do not know of anywhere that does not have Bio in the fuel ,it is a cetain booster.
I am not a fan of adding anything to the fuel, especially for a problem that does not exist.
I worked on class eights they use as much fuel in one day, as many of us do in a month, very few ever use anything in their fuel, an anti-gel, if they are traveling north in the winter months. Many of them go millions of miles, without ever having an injector problem, when I did an overhaul at a million miles, I never changed the injectors.
You can add whatever you want, Harry has me convinced the striction aditive he likes is a good idea, what I found is that the people that add the most additives have the most problems.
Just a thought!
Johnp3 is offline
post #9 of 11 (permalink) Old 04-20-2014, 07:39 PM
nitrogen's Avatar
While I don't see the need for additives to be so important it could also be that those people are more aware of how their engine runs. Myself I don't really get too religious about running an additve. When I do it's just the archoil oil and fuel additives. However at 125000 I split an injector tip and the other 7 all tested out of parameters for "over delivery" , certainly could be a wear/lubricity issue. Still run awesome right up until the last 8 hours of engine time
Canadian Club #31
nitrogen is offline
post #10 of 11 (permalink) Old 04-21-2014, 12:10 AM
harry6.0's Avatar
Injector nozzle-tip cracks or splits can be a result of low fuel pressure or water in the fuel, or just defective manufacturing or wear and tear.
When your injector tip split did it take out the engine?
Injector nozzle-tip failures can be very serious, and I have seen them destroy an engine.
Harry
harry6.0 is offline
2 stroke oil 03lariatsd 2003-2007 6.0L Power Stroke 59 07-16-2009 06:45 AM
two stroke oil? maltby4459 5.9L Cummins (1998.5-2002) 9 04-16-2009 04:09 AM
2 stroke oil Taylor34 General Ford Truck and Excursion 15 03-23-2009 09:33 PM
2 stroke oil use.... mpdxtreme 1994-2003 7.3L Power Stroke 33 02-26-2008 03:06 PM
2 stroke oil Kip 1994-2003 7.3L Power Stroke 94 08-25-2007 01:45 AM
