Oil Leak @ Bellhousing? Here's Why.... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by makuloco2000, this thread has received 6 replies and been viewed 6503 times.
post #1 of 7 (permalink) Old 04-19-2014, 04:58 PM Thread Starter
This is an often overlooked source of engine oil leaks that everyone assumes is coming from the oil pan or rear main seal. Most of the time it is from split CAC tube hoses that only appear to have oil moisture to them upon further inspections. Take a look I show you what to look for how it pools up and where it all comes from and how to change them out properly so the angles are correct and there is no blow offs.
http://www.youtube.com/watch?v=H5H8HJL0d1o
Check out all my Ford Tech Repair Videos @
http://www.youtube.com/user/FordTechMakuloco
Please Subscribe. Always something new and interesting!
makuloco2000 is offline
The Following 2 Users Say Thank You to makuloco2000 For this addition to TDG:
harry6.0 (04-20-2014), jdydiesel (04-20-2014)
post #2 of 7 (permalink) Old 04-20-2014, 02:58 AM
harry6.0's Avatar
Mines had a slight bed plate seal leak since new, but has never gotten any worse, just a slight oil drip gathers on the lower bell housing. I never had it fixed even when under warranty due to my reasoning that it was not worth me having to chance my luck of possibly having some dealer hack tear my motor out and apart for a dribble..the talent can vary dramatically in a dealerships technician pool. Don't get me wrong, as I'm not in any way implying you, I would be more than happy to have someone like you work on my truck if it were a warranty situation or not.
Thanks for all the great videos and tips! Keep'em coming!
Harry
harry6.0 is offline
post #3 of 7 (permalink) Old 04-20-2014, 03:14 AM
Dually Club #3
jdydiesel's Avatar
Mine has always had an oil leak. I have had the turbo replaced, bed plate o-ring has been replaced, and all boots replaced. I am going to look at what was shown in the video and see if my boot is leaking. I do not have any oil residue on the top of the boot, so I do not think that is what is leaking. But one day I might find it.
Jason
72 F-250 Gasser.FOR SALE
jdydiesel is offline
The Following User Says Thank You to jdydiesel For this addition to TDG:
harry6.0 (04-21-2014)
post #4 of 7 (permalink) Old 04-20-2014, 03:40 AM
Upon tear down of my engine I finally found my small oil leak. It was the dipstick oil tube o-ring was missing.
lenzhotrod is offline
The Following User Says Thank You to lenzhotrod For this addition to TDG:
post #5 of 7 (permalink) Old 05-24-2014, 01:39 AM Thread Starter
Wow that is an odd ball don't think I have ever seen one of those leak.
post #6 of 7 (permalink) Old 05-24-2014, 04:31 PM
That was a common oil leak on the 7.3.
post #7 of 7 (permalink) Old 05-30-2014, 07:45 PM Thread Starter
Oh yeah it was with a that funky design I remember those.
OK fuel leak stopped now oil leak Stacked6600 1994-2003 7.3L Power Stroke 7 01-27-2011 04:37 AM
LB7 oil burning exhaust and oil leak. Help Plse lb7duramax Duramax 2001-2004 (LB7) 4 05-14-2010 05:28 AM
Oil Dipstick Tube Oil Leak TLadd 5.9L Cummins 12 Valve (1994-1998.5) 2 06-29-2009 06:12 AM
Oil Leak Or Boost Pressure Leak At Hot Side Charge Air Cooler (cac) Duct PSDPlayer 2003-2007 6.0L Power Stroke 2 01-12-2007 05:17 AM
Oil drop on Bottom of Bellhousing John Boy 2003-2007 6.0L Power Stroke 24 12-15-2005 11:49 PM
