6.0 2004 won't start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by UnderpressureNM, this thread has received 26 replies and been viewed 2389 times.
post #1 of 27 (permalink) Old 05-24-2014, 01:13 AM Thread Starter
Underpressure76nm
Exclamation 6.0 2004 won't start
Havin trouble guys need help my truck got a 2285 code before it died a week later, took it apart oil cooler was plugged, it used to start if hot outside but not cold,,,did egr delete while in there,replaced oil cooler and gaskets ect, rebuilt ipr, scanguage reads icp good ficm dropped to 22 while cranking, but got no ipr reading the ipr screen was off when I pulled it out but clean no debri,,,,need help
UnderpressureNM is offline
post #2 of 27 (permalink) Old 05-24-2014, 01:35 AM
Are you getting FICM sync?
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD BilletWaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
bismic is offline
The Following User Says Thank You to bismic For this addition to TDG:
UnderpressureNM (05-24-2014)
post #3 of 27 (permalink) Old 05-24-2014, 01:53 AM Thread Starter
Underpressure76nm
Thank u for the reply and yes it did sync
post #4 of 27 (permalink) Old 05-24-2014, 03:08 AM
harry6.0's Avatar
"ficm dropped to 22 while cranking"
If your only getting 22v while cranking, thats an issue with the FICM right there, needs repair.
If you have over 500psi ICP, then your IPR should be in the ballpark at the very least, even though your not getting a reading...could be an issue with the ScanGauge, maybe it lost memory for that reading, try reloading the IPR coding into the ScanGauge.
When my original ficm died, it dropped to 24v and would not start.
Harry
harry6.0 is offline
post #5 of 27 (permalink) Old 05-24-2014, 03:40 AM
harry6.0's Avatar
Not sure if I'm misreading your post. But anyhow, if your still getting a P2285 fault and have no IPR reading, then...
1. you have a bad IPR
2. you have bad or chaffed wiring
Harry
harry6.0 is offline
post #6 of 27 (permalink) Old 05-24-2014, 04:28 AM Thread Starter
Underpressure76nm
Cool
Thanks for the reply,,,I sent the ficm out should have it in a day or two even put brand new batteries in, but the icp pressure was good it did sync up, will the ipr keep it from starting I rebuilt it but the poppet or whatever didn't shake to freely after a can of wd40,,,
The Following User Says Thank You to UnderpressureNM For this addition to TDG:
harry6.0 (05-24-2014)
post #7 of 27 (permalink) Old 05-24-2014, 04:33 AM Thread Starter
Underpressure76nm
Wires look good ,,,
No oil ,,,also no codes
post #8 of 27 (permalink) Old 05-24-2014, 02:37 PM
harry6.0's Avatar
Yes, a faulty IPR can keep it from starting, but wait till you get your repaired ficm installed before going any further.
Harry
harry6.0 is offline
post #9 of 27 (permalink) Old 05-24-2014, 07:01 PM Thread Starter
Underpressure76nm
Thanks Harry they called this morning they said it needed a half shell repair so I'm waiting to get it back,,,they tested it on their truck before sending it back and it wasn't good enough after he did whatever to it,,,,appreciate ur help I sent it to ,,ficm fixer,,in Texas so well see how it goes,,,
harry6.0 (05-25-2014)
post #10 of 27 (permalink) Old 05-28-2014, 01:20 AM Thread Starter
Underpressure76nm
Harry I got the ficm on and I have it idling,,(which is great) but it died after about two minutes lots of smoke black at first then grey,,,,now it sounds like I have no boost the scanguage reads0.8. ?,,,,I hear a whirring sound at idle not loud but there? But no power seems like,,,,,after revving it after a few minutes it sounded good but is huffing then died?
Tags
6.0, no start, powerstroke 2004 f350
Won't start liftruck 2003-2007 6.0L Power Stroke 1 03-31-2011 12:12 AM
6.5 won't start cowboy128 6.5L Diesel Engine 6 01-31-2011 12:31 PM
won't start destructive 2003-2007 6.0L Power Stroke 7 08-27-2010 01:40 AM
won't start 98 12-valve32 5.9L Cummins (1998.5-2002) 8 04-16-2008 02:08 AM
95 won't start ericandkayti 1994-2003 7.3L Chips & Tuners Forum 1 01-10-2008 10:05 PM
