06 Died while running/crank no start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by nolapoolguy, this thread has received 5 replies and been viewed 749 times.
post #1 of 6 (permalink) Old 05-26-2014, 06:23 PM Thread Starter
2006 F250 6.0l
168000 miles
Since I bought truck 12 months ago (113000miles were on it) oil/filter is changed every 4500 miles and the fuel filters are changed every 3rd oil change.
Serpentine belt and tensioner were replaced 5 months ago, that is the only issue ive had with truck to date.
Thursday CEL came on and I bought a scanguage pulled code p0676.
Friday truck started fine as always, drove about 130 miles and while exiting hwy truck died.
:Had truck towed, programmed scan guage and have these readings
key on:
ICP 0
IPR 10.0%
FMP 48.5 v
FLP 11.5v
Cranking
ICP 168
IPR 73.2%
FMP 48.0 v
FLP 11.0v
Oil guage climbs within a few seconds of cranking, pulled fuel filter cap and getting fuel.
from what Ive read on here im guessing STC fitting is the likely problem?
Any help and guidance would be appreciated.
nolapoolguy is offline
post #2 of 6 (permalink) Old 05-26-2014, 07:12 PM
more than likely the stc fitting on yours seperated. you have to pull the turbo to access it. some people have had luck replacing it without removing the intake but if you still have the stock EGR valve and cooler I would recommend getting a delete kit or a bullet proof diesel cooler and also replacing the oil cooler since you're there already for piece of mind.
may have a bad icp sensor. it's on the passenger valve cover you could try disconnecting the connector and see if the truck fires up.
2003 Ford F-250 SuperCab FX4
6.0L Turbo Diesel
RCD EGR Delete Kit, Sinister Diesel Coolant Filter, Warren Diesel 155cc/Stock Nozzle Injectors, ARP Headstuds, Innovative Diesel Tunes, 5" Straight Pipe Exhaust, Blue Spring Mod, 4.5" Lift Kit
2006 Ford F-250 CrewCab FX4
6.0L Turbo Diesel
Innovative Diesel Tunes, 4" MBRP Single Stack Kit w/ Side-By-Side Dual Aussie Stack, Blue Spring Mod, RCD EGR Delete, Warren Diesel 155cc/30% Nozzle Injectors, Sinister Coolant Filter Kit, One Piece STC Fitting, Updated Standpipes/Dummy Plugs, Variant Raim Air/Cold Air Intake, 6" Lift Kit, 37s on 20" wheels,
Fighting Irish is offline
The Following User Says Thank You to Fighting Irish For this addition to TDG:
nolapoolguy (05-26-2014)
post #3 of 6 (permalink) Old 05-26-2014, 07:17 PM Thread Starter
Thanks, I tried the ICP disconnect still crank/no start. and was reading about the egr delete. since I will be in it already would it be a good idea to do the stand pipe and dummy plugs also? And with the reading i got would it be safe to say the IPR and ICP are good?
post #4 of 6 (permalink) Old 05-26-2014, 10:25 PM
IPR values look funny. Should be 14.8 or so at KOEO and 84% cranking.
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD BilletWaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
bismic is offline
The Following User Says Thank You to bismic For this addition to TDG:
nolapoolguy (05-28-2014)
post #5 of 6 (permalink) Old 05-27-2014, 04:14 AM
Old Fart
dbennett48's Avatar
The ICP value is to low when cranking. You need 500 or higher before the computer will fire the injectors.
Dave
Completely Stock.
KK6TNI - HAM Radio
dbennett48 is offline
The Following User Says Thank You to dbennett48 For this addition to TDG:
post #6 of 6 (permalink) Old 05-27-2014, 05:44 AM
harry6.0's Avatar
High IPR and low ICP = high pressure oil leak in your case, as your low pressure oil gauge is moving which is a good thing.
You can air test the system from the ICP sensor if you have the ability to close the IPR, but it's nearly guaranteed your going to go at the STC fitting first anyway.
I agree with everyone and everything thats been said already.
Harry
harry6.0 is offline
died when it wasnt even running crankytrucker 2003-2007 6.0L Power Stroke 8 12-07-2010 06:47 AM
running fine the died midnightcaper 5.9L Cummins 12 Valve (1994-1998.5) 9 11-30-2007 06:05 AM
CRANK NO START, HARD START, RUNS ROUGH AT IDLE - 6.0L 2005 F, E-Series,and Excursion PSDPlayer 2003-2007 6.0L Power Stroke 0 10-08-2005 08:32 AM
