6.0 turbo problems - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by UnderpressureNM, this thread has received 16 replies and been viewed 1842 times.
post #1 of 17 (permalink) Old 06-06-2014, 10:42 PM Thread Starter
Underpressure76nm
Thumbs down 6.0 turbo problems
Truck sucks off the jump (literally) once up to second turbo kicks in,,but remembering back this truck could spin my tires if I held the brake. These days it won't, ford put a turbo under warranty (years ago)or did they?,, anyways yesterday went into limp mode and I found a small tear on the map senser hose but I'm also feeling air leaking from the turbo clamp holes on the manifold? Is this right?
UnderpressureNM is offline
post #2 of 17 (permalink) Old 06-06-2014, 11:51 PM
Old Fart
dbennett48's Avatar
No. You have at least one leak in the turbo to intercooler to engine lines. All of these connections need to be air tight. There are several large hose clamps that may be leaking. Try to tighten these up and see if this solves your problem. Replace the MAP sensor hose. By the way, what are you trying to fix? Add this information to your signature by going to the USER CP.
Dave
Completely Stock.
KK6TNI - HAM Radio
dbennett48 is offline
The Following User Says Thank You to dbennett48 For this addition to TDG:
UnderpressureNM (06-07-2014)
post #3 of 17 (permalink) Old 06-07-2014, 01:22 AM Thread Starter
Underpressure76nm
I checked everything all clamps I'm going to put new ones but they all look good, except the smallest one turbo to intercooler had some fraying in it and hairline cracks so I'm replacing it. sorry it's a 2004 powerstroke 6.0, just got it running put egr delete and new oil cooler while I was in there all new gaskets, new oil coolant ect, ran good then just no power I've blown boots off before but the truck doesn't even want to shift(barely at 3300) into second and third. I replaced map hose and nothing,
2004 6.0 king ranch 350 adt egr delete, adt egr cooler, scanguage 2, k&n intake and filter,blue spring upgrade,banks exhaust from turbo back 4" 5th wheel and wood hauler
post #4 of 17 (permalink) Old 06-07-2014, 03:14 AM
Weld engineer's Avatar
I'd suggest some aftermarket boots and clamps. I like the BD ones I put on never blown a boot off since.
Dbennett is referring to your truck info in your signature. It eliminates the guessing game.
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
The Following 2 Users Say Thank You to Weld engineer For this addition to TDG:
dbennett48 (06-07-2014), UnderpressureNM (06-07-2014)
post #5 of 17 (permalink) Old 06-07-2014, 04:18 AM Thread Starter
Underpressure76nm
Thanks for the replies
All hoses look good the truck takes forever to shift also like it's not building pressure? I just put new ipr in and two days later it was junked up(screen). Put new ipr ran okay for two more days now no power, I also found oil right before the intake elbow in the hose,
post #6 of 17 (permalink) Old 06-07-2014, 04:21 AM Thread Starter
Underpressure76nm
Lightbulb
But the turbo is leaking from the housing clamp holes why is that
post #7 of 17 (permalink) Old 06-07-2014, 04:33 AM
harry6.0's Avatar
Can you point out the leak location from any of these pics...
http://www.backglass.org/duncan/ps60...l/ps60_031.jpg
http://www.backglass.org/duncan/ps60...l/ps60_034.jpg
http://www.backglass.org/duncan/ps60...l/ps60_036.jpg
Harry
harry6.0 is offline
post #8 of 17 (permalink) Old 06-07-2014, 05:57 AM Thread Starter
Underpressure76nm
There's tiny holes if your looking at the Vgt solenoid there's a clamp that goes around the turbo housing it has a couple tiny holes one on each side of the turbo a little smaller than a ballpoint pen I'm getting air from those
post #9 of 17 (permalink) Old 06-07-2014, 06:00 AM Thread Starter
Underpressure76nm
{\rtf1\ansi\ansicpg1252
{\fonttbl\f0\fnil\fcharset0 HelveticaNeue;}
{\colortbl;\red255\green255\blue255;\red34\green34 \blue34;}
\deftab720
\pard\pardeftab720\qc\partightenfactor0
\f0\fs30 \cf2 \expnd0\expndtw0\kerning0
\outl0\strokewidth0 \strokec2 \
post #10 of 17 (permalink) Old 06-07-2014, 06:02 AM Thread Starter
Underpressure76nm
If you look up [picture of Vgt solenoid on 6.0 diesel) you can see a picture by diesel power of the little holes where I'm getting air from on google search appreciate your guys help very much
Turbo problems??? BrianHonda629 2003-2007 6.0L Power Stroke 14 09-11-2010 08:48 PM
Turbo problems again StrokingForFun 2003-2007 6.0L Power Stroke 5 12-17-2009 02:31 PM
turbo problems sawmillman Duramax 2004.5-2005(LLY) 0 02-29-2008 02:06 AM
Turbo Problems Rusty-Carlton 1994-2003 7.3L Power Stroke 11 03-29-2007 04:28 AM
01 7.3 turbo problems Rave 1994-2003 7.3L Power Stroke 16 09-15-2006 01:39 PM
