2007 wheel bearing and hub assembly removal - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JohnUlfers, this thread has received 4 replies and been viewed 1048 times.
post #1 of 5 (permalink) Old 06-19-2014, 07:34 PM Thread Starter
I'm sure there's a forum about this somewhere but I just received my new timken hub assembly (sp940200) and I'm not 100 percent sure how to remove the one on my truck so I can install the new one. Does anyone have a step by step procedure with pictures or possibly a video? There's one on YouTube but it seems like the guy skips some parts.
I have a 2007 f350 with the 6.0l, SRW 4x4
JohnUlfers is offline
post #2 of 5 (permalink) Old 06-19-2014, 09:22 PM
Old Fart
dbennett48's Avatar
I have done a couple of front bearing replacements. It is not hard and goes pretty much like a two bearing front axle. It is a unit bearing, that is ONE Bearing and NOT Two Bearings. That is the difference right there. Everything is pretty much as it has always been.
Dave
Completely Stock.
KK6TNI - HAM Radio
dbennett48 is offline
post #3 of 5 (permalink) Old 06-20-2014, 12:21 AM Thread Starter
I should have said this is my first time attempting this. Can't seem to get the caliper mount bolts loose. Any tricks besides ice breaker?
post #4 of 5 (permalink) Old 06-20-2014, 02:23 AM
this is for the front correct? if so..... I use an impact wrench otherwise breaker bar with a piece of pipe attached to the end for more leverage if the breaker bar itself isn't enough.
with the 4wd you have to take the 4wd hub off and there is a copper colored snap ring that holds the axle shaft then you have 4 nuts on the back of the knuckle that need to come out. sometimes the bearing gets a little stuck but usually a few good hard whacks with a big hammer and it starts coming out. I usually work one side then the other side hitting it with a hammer til it is loose and I can pull it out by hand.
2003 Ford F-250 SuperCab FX4
6.0L Turbo Diesel
RCD EGR Delete Kit, Sinister Diesel Coolant Filter, Warren Diesel 155cc/Stock Nozzle Injectors, ARP Headstuds, Innovative Diesel Tunes, 5" Straight Pipe Exhaust, Blue Spring Mod, 4.5" Lift Kit
2006 Ford F-250 CrewCab FX4
6.0L Turbo Diesel
Innovative Diesel Tunes, 4" MBRP Single Stack Kit w/ Side-By-Side Dual Aussie Stack, Blue Spring Mod, RCD EGR Delete, Warren Diesel 155cc/30% Nozzle Injectors, Sinister Coolant Filter Kit, One Piece STC Fitting, Updated Standpipes/Dummy Plugs, Variant Raim Air/Cold Air Intake, 6" Lift Kit, 37s on 20" wheels,
Fighting Irish is offline
post #5 of 5 (permalink) Old 06-20-2014, 01:08 PM Thread Starter
Thanks for all the help guys! I got it all apart last night and put the new hub assembly on. I ended up breaking all of my snap ring pliers (cheap tools) so I wasn't able to get the new snap ring on yet. I'm going to pick a new one up after work tonight. Any suggestions on good but affordable snap ring pliers?
Also, I'm guessing I should re-pack the 4wd hub with grease before putting it back in?
Tags
bearing, front, hub, srw, wheel
Non adjustable wheel bearing assembly AaronF Medium and Heavy Duty 3 06-20-2012 09:06 PM
03 hub assembly removal intimidtr3 General Dodge Discussion 2 01-10-2008 04:23 AM
Where can I find an exploded view of my hub assembly? Lonesome7.3 The Parking Lot 8 09-27-2007 07:11 PM
Need hub assembly ndrorydr General Ford Truck and Excursion 1 03-30-2007 10:08 PM
Cant remove wheels from hub assembly Help Diesel Guy The Parking Lot 14 08-30-2006 05:50 PM
