6.0 Bucking kicking at cruise speeds - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dalpilot, this thread has received 4 replies and been viewed 2077 times.
post #1 of 5 (permalink) Old 12-23-2008, 04:55 AM Thread Starter
Dalpilot's Avatar
Images: 1
If your getting this and its throwing a 2287 code it is most likely your check valves in the oil rails. It took me, (and several ford "techs" who never got it) 8 months to figure this out. Save yourself some time.
Dalpilot is offline
The Following 2 Users Say Thank You to Dalpilot For this addition to TDG:
Binderpower (10-11-2010), harry6.0 (10-09-2010)
post #2 of 5 (permalink) Old 12-23-2008, 05:19 AM
TDG Mafia #76
John_DeereGreen's Avatar
Thanks for the info Tim...good to see you back!!!
Jarrett
04.5 qcsb commonrail
Smarty TnT
John_DeereGreen is offline
post #3 of 5 (permalink) Old 12-24-2008, 12:56 AM
fordsuperduty01's Avatar
Thanks man!! mine does this under light acceleration with the T/C locked but i have no codes.
2005 F-250 6.0L King Ranch FX4. 125k miles, Edge Platinum, EGR delete, MBRP turbo back exhaust without cat, an 03 turbo, and 4.30 gears.
A.S.E. Master certified automotive and light duty diesel technician.
fordsuperduty01 is offline
post #4 of 5 (permalink) Old 10-07-2010, 11:29 PM
Is there a way to test the check valves while the rail is apart?
06' F250 Mods:
Performance related:
-K&N E-0780 Air Box, ZooDad Mod
-Garrett Powermax Turbo, CFM+ Smallmouth Intake Manifold
-Blue Fuel Pressure Spring, Large fuel lines from pressure regulator to heads
-MBRP 4" Turbo back exhaust; cat installed
-SCT SF3 Tuner w/SRL custom tunes from Matt at GearheadAutomotivePerformance.com
Reliability Mods:
-Refurbished 50 volt FICM, Eliminated STC fitting, upgraded stand pipes and dummy plugs, Bulletproof Diesel EGR cooler, upgraded turbo oil supply and drain
-Oil change rotation; 5k-5W40/5k-15W40/5k-15W40
--Rotella T5 or Valvoline Blue Extreme 5W40, Rotella or NAPA 15W40, Archoil 9100 friction modifier (16 ounces to crank case; 10 ounces to each differential)
--2/3 Qt. tcw3 2 cycle oil per tank Power Service (5 oz. Stanadyne every tank)
-Cooling system flush with Restore and VC-9 @ 73,000 miles w/new thermostat
-Eliminated clunk while sitting at a light (75,000 miles); Lubed rear drive-shaft spline with Ford lubricant; Symptom returned at 100,000 miles...re-lubed at 112,000 miles....wow!! it's so smooth again.
Miscellaneous:
-1/2" shim on carrier bearing mount
-Batteries:
--Original Motorcraft lasted 4 1/2 years
--AutoZone Duralast Gold lasted less than 3 years
---(with 2/0 cables between + terminals)
--Still on 2nd set of Autozone Gold (replaced free)
-Alternator:
--DC Power 185 amp
Future Mods:
-Teflon sway bar bushings
-Moog Ball Joints (originals seem to be holding tight at 108,000 miles; it's just a daily driver, so this seems to make sense)
-Cooling system filter
-OEM HG/ARP studs
bustedknuckles is offline
post #5 of 5 (permalink) Old 10-09-2010, 08:52 PM Thread Starter
Dalpilot's Avatar
Images: 1
Nope, but mine wound up also having an injector issue about 5 months later as well.
Dalpilot is offline
