2003 F 350 6.0 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Stormgreen, this thread has received 15 replies and been viewed 1478 times.
post #1 of 16 (permalink) Old 07-22-2014, 11:38 PM Thread Starter
2003 F 350 6.0
My 2003 F350 has been an absolute work horse and has over 300K on it . Recently there a small leak in the radiator . I had the radiator replaced and now the truck overheats all the time . Any suggestions ?
If I leave the truck idling it does not overheat but start driving it and it overheats within a couple of miles
Any advice greatly appreciated
Stormgreen is offline
post #2 of 16 (permalink) Old 07-22-2014, 11:51 PM
Old Fart
dbennett48's Avatar
Thermostat. They do go bad.
Dave
Completely Stock.
KK6TNI - HAM Radio
dbennett48 is offline
The Following User Says Thank You to dbennett48 For this addition to TDG:
Stormgreen (07-24-2014)
post #3 of 16 (permalink) Old 07-23-2014, 02:03 AM
Weld engineer's Avatar
Who replaced it? I'd agree thermostat but suprised they didn't suggest it when the radiator was changed out. What coolant did they put in hopefully ford gold flavored. I had to replace mine and found a good used one at the spare parts yard.
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
The Following User Says Thank You to Weld engineer For this addition to TDG:
post #4 of 16 (permalink) Old 07-23-2014, 03:06 AM
harry6.0's Avatar
Is the fan clutch hooked up and working?
Harry
harry6.0 is offline
post #5 of 16 (permalink) Old 07-23-2014, 07:19 PM Thread Starter
Thank you very much for taking the time to respond . The radiator was replaced by Meineke . They also installed a new thermostat after I returned the truck because it was seriously overheating . However this did nothing to stop the problem
Is it possible that a blown gasket would be causing the problem ? If so any idea what I should expect to pay to resolve the problem
I will try the ford gold coolant but it would appear that the over heating is so serious that there must be a more serious problem .
Not sure about the fan ? How would I confirm whether it is working ?
Again thank you very much for the advice
post #6 of 16 (permalink) Old 07-23-2014, 07:57 PM
Old Fart
dbennett48's Avatar
Hold on there. If you suspect a blown headgasket; you had best verify that it is shot. Here is a kit to test the presents of CO2 in the coolant: http://www.marineandreef.com/Hagen_F...KgYaAjaI8P8HAQ
Good Luck!
Dave
Completely Stock.
KK6TNI - HAM Radio
post #7 of 16 (permalink) Old 07-24-2014, 02:38 AM
You need to find out what coolant they put in it. If they used green glycol you will have a clogged oil cooler and EGR cooler which will be a big problem fast.
Fan will lock up around 225 coolant temp and roar like a jet engine. You can pick up a scangauge to see the fan speed. I'd recommend it to see your oil and coolant temp.
Engine rpm 2000 at 190 deg fan speed around 600-700
Engine rpm 2000 at 215 deg fan speed around 1500 rpm
Engine rpm 2000 at 225 deg fan speed around 3000 rpm.
http://www.scangauge.com/products/scangaugeii/. Pick them up online or autozone.
When you say overheating is that the temp gauge or is coolant coming out of the degas(coolant) tank?
post #8 of 16 (permalink) Old 07-24-2014, 10:22 PM Thread Starter
I am using Dexcool Prestone coolant . I notice the roaring sound when it begins to overheat ( I'm glad I now know what this is ) . Usually begins to happen after about 5 miles
The gauge then goes off the charts and there is a tremendous amount of steam , pressure and fluid on the degas tank lid - just going near it looks as if it's about to explode
Again , much appreciate the advice . Just trying to make smart financial decision on trucks future ( I got a new transmission and new fuel injectors last year )
post #9 of 16 (permalink) Old 07-25-2014, 01:54 AM
harry6.0's Avatar
Got to start from the begining on this one...
1. Was it overheating like this before you took it in for the radiator?
2. Dexcool is the wrong coolant to mix with any of the original Ford gold coolant and can contaminate and clog the cooling system if the two were mixed.
3. I'm suspecting your cooling system is either totally clogged up and contaminated, or you have a blown egr cooler or blown headgasket-s or both, especially if it's puking coolant out of the cap.
Harry
harry6.0 is offline
Stormgreen (07-25-2014)
post #10 of 16 (permalink) Old 07-25-2014, 03:33 AM Thread Starter
Great questions Harry . The strange thing is that it only began to overheat when the radiator was replaced . The radiator had a small leak for at least 6 months and we never had any over heating issues until we replaced it
Ok - need to use correct coolant .
Sounds more and more like a blown gasket - just strange that we only had issues once the radiator was replaced ?
2003 F-350 DRW 4x4 JimTJr Vehicles For Sale 5 03-08-2011 02:13 AM
2003 F-350 Oasis Report FireRescueFL Ford Oasis requests 4 10-13-2010 09:03 PM
2003 f-350 report mxracer201 Ford Oasis requests 6 04-04-2009 07:56 PM
2003 f 350 CrewCab Stroker81 Whats Been Sold 3 03-02-2007 04:31 AM
2003 f 350 CrewCab Stroker81 Whats Been Sold 4 10-19-2006 03:48 PM
