2004 battery drain - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by gbb, this thread has received 7 replies and been viewed 945 times.
post #1 of 8 (permalink) Old 07-29-2014, 06:26 PM Thread Starter
gbb
2004 battery drain
Have a 04 and passenger side battery has bad connection on red wire that supplys altenator circuit. The connection was intermittent and is now repaired. There is a heavy draw on the red wire. I have to disconnect otherwise batteries will totally discharge. I suspected leaky diode in alternator. Replaced altenator but no change. Resistance to ground shows no short. ANY ideas?
gbb is offline
post #2 of 8 (permalink) Old 07-29-2014, 06:51 PM
Old Fart
dbennett48's Avatar
Clean ALL of your battery and ground connections. Corroded connections do leak power to ground, killing the batteries.
Dave
Completely Stock.
KK6TNI - HAM Radio
dbennett48 is offline
post #3 of 8 (permalink) Old 07-29-2014, 09:16 PM Thread Starter
gbb
Battery drain
I checked all connections. I have a 10 amp draw with batteries out of circuit on small red cable
gbb is offline
post #4 of 8 (permalink) Old 07-29-2014, 11:06 PM
With the engine shut off put a wrench to the pulley if it is attracted then the alternator field is not shutting down.
Just a thought!
Johnp3 is offline
post #5 of 8 (permalink) Old 07-30-2014, 06:56 AM
The large red wire goes directly to the battery positive (sometimes thru a fuse link). If you have a load on it your alternator or regulator is bad.
lenzhotrod is offline
post #6 of 8 (permalink) Old 08-05-2014, 05:23 PM Thread Starter
gbb
Battery drain
Finally got back to battery issue. Dug out old ammeter. Draw on battery to cab is 300 ma. On red to alternator it is 1.4A. Disconnect alternator it is still same. Problem points to glow plug controller.
gbb is offline
post #7 of 8 (permalink) Old 08-05-2014, 05:43 PM
Old Fart
dbennett48's Avatar
How did you arrive at that conclusion? There are many other things that draw power when the key is off, like radios.
Dave
Completely Stock.
KK6TNI - HAM Radio
post #8 of 8 (permalink) Old 08-29-2014, 05:59 PM Thread Starter
gbb
Battery Drain
I monitored draw with ammeter as I removed all fuses. There was no change so I went back under hood. Only thing that could draw high current was altenator or controller. It was glow plug controller. Most probable cause was broken wire on postive post on battery. Ir must have arced.
gbb is offline
2004 6.0 dead ball bearing on drain plug magnet sheldondrywall 2003-2007 6.0L Power Stroke 5 02-02-2010 11:04 PM
$29 Battery Maintainers (battery tenders) bushpilot General Diesel 4 12-29-2009 02:19 PM
Battery drain? 03ford 2003-2007 6.0L Power Stroke 1 09-09-2007 06:50 AM
Oil drain?? rmk1100 5.9L Cummins (2003-2007.5) 2 05-04-2007 04:25 PM
Battery Drain? D_B General Dodge Discussion 11 12-08-2006 05:34 AM
