6.0l wont't start PLEASE HELP!!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jdydiesel, this thread has received 12 replies and been viewed 1264 times.
post #1 of 13 (permalink) Old 10-05-2014, 08:41 PM Thread Starter
Dually Club #3
jdydiesel's Avatar
My 06 in the signature below won't start. I just replaced the egr cooler, oil cooler and turbo. WHen assembling I prefilled the oil reservoir. After I was done I was able to get the engine started pretty quickly. Ran for 10 minutes just fine. Shut it off to check fluid levels. Now it won't start. Please help, how do I get it to start????
Jason
72 F-250 Gasser.FOR SALE
jdydiesel is offline
post #2 of 13 (permalink) Old 10-06-2014, 12:32 AM
Old Fart
dbennett48's Avatar
Your FICM (Fuel Injector Control Module) could be going south. Here is how you can check the voltages; www.swampsdiesel.com . I can't paste the address. Look under How to Order a FICM and it will tell you how to check your FICM for 48 volts.
Dave
Completely Stock.
KK6TNI - HAM Radio
dbennett48 is offline
post #3 of 13 (permalink) Old 10-06-2014, 01:49 AM Thread Starter
Dually Club #3
jdydiesel's Avatar
I guess it could be, but I am not getting any codes and it is one of the upgraded units I bought from FICMrepair.com. I will get the voltages when I get back to the truck.
Jason
post #4 of 13 (permalink) Old 10-06-2014, 02:35 AM
Weld engineer's Avatar
Need a scangauge to get some data. Unplug your ICP sensor it's by all the stuff you just changed maybe it died or you damaged it. 500 psi required to start.
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
The Following User Says Thank You to Weld engineer For this addition to TDG:
jdydiesel (10-06-2014)
post #5 of 13 (permalink) Old 10-06-2014, 02:55 AM Thread Starter
Dually Club #3
jdydiesel's Avatar
The ICP sensor is the one the is the passenger side valve cover correct?
Jason
post #6 of 13 (permalink) Old 10-06-2014, 03:04 AM
harry6.0's Avatar
Yes, it sticks out the top of passenger side valve cover.
1. You may just have a bunch of air in the high pressure oil system, need to hook up battery charger and crank the heck out of it.
2. You may have a high pressure leak? Maybe something didn't seal up properly or came loose during reassembly?
3. Being it started up on the filled oil reservoir, makes me think air is most likely.
Harry
harry6.0 is offline
post #7 of 13 (permalink) Old 10-06-2014, 03:07 AM Thread Starter
Dually Club #3
jdydiesel's Avatar
So how do I get the air out of it? I have cracked it several times until it gives me a TCB fault.
Jason
post #8 of 13 (permalink) Old 10-06-2014, 03:18 AM Thread Starter
Dually Club #3
jdydiesel's Avatar
Just tried to start. Spins over very fast and after about 5 seconds, it tries to fire slightly, nowhere near enough to catch and run but at least there is a little life. Now I also got two codes. P0264 Inj Cylinder 2 and P0273 Inj cylinder 5 is what it tells me. Is this my FICM going south again?
Jason
post #9 of 13 (permalink) Old 10-06-2014, 03:30 AM
You need to see what FICM voltages are during cranking. SG2 will tell you. You sure you have fuel supply?
post #10 of 13 (permalink) Old 10-06-2014, 03:45 AM
harry6.0's Avatar
Trailer Brake Controller fault should not be any issue causing a no start.
The injector codes could be a clue....recheck all fuses and connections and make sure FICM is plugged in securely.
Harry
harry6.0 is offline
99 wont start bsutton2000 5.9L Cummins (1998.5-2002) 5 10-24-2010 11:26 PM
Wont Start bsutton2000 2003-2007 6.0L Power Stroke 3 06-22-2009 09:24 PM
wont start silvervic99stang 7.3L and 6.9 IDI (Pre 1994) 5 06-18-2009 04:40 AM
