2005 6.0 hard starting - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by nenzi71, this thread has received 6 replies and been viewed 1238 times.
post #1 of 7 (permalink) Old 11-25-2014, 10:47 PM Thread Starter
I have a 2005 6.0 that has sat for about a year. When you go to start it it wont start until the oil pressure gauge moves on the dash. Crank it for about 10 seconds its see's oil pressure. Stop then crank it again and it fires. It does this if its hot or cold and everytime. Any help would be appreciated.
nenzi71 is offline
post #2 of 7 (permalink) Old 11-26-2014, 12:25 AM
Weld engineer's Avatar
Check the oil level is it full?
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
post #3 of 7 (permalink) Old 11-26-2014, 05:33 AM
harry6.0's Avatar
First check the oil like Weld recommended.
But also check the oil filter and cap. Make sure the oil filter cap isn't one of those tall aftermarket type ones like Napa sells. These caps can cause low oil flow issues especially when a shorter factory size oil filter is put in a tall cap. You may also have a low oil pressure pump issue, but thats a whole other story that you don't want happening.
Maybe just try doing a fresh engine oil and filter change with a Motorcraft filter and the factory oil cap. Also make sure no debri from an old oil filter cartridge isn't stuck down inside the oil filter housing.
Also, recommend a ScanGaugeII and program it for the Ford 6.0L diesel, then read the vitals like FICM voltages, IPR% and ICP psi.
Harry
harry6.0 is offline
Weld engineer (11-26-2014)
post #4 of 7 (permalink) Old 11-27-2014, 03:06 AM
Levi'sford's Avatar
Where is the best place to get a scan guages. Need one for the 450. Thanks
2015 F350 Platinum, Crew Cab, Long Bed, 3.55, FX4, B&W Turnover Ball, Firestone Riderites w/ compressor
Levi'sford is offline
post #5 of 7 (permalink) Old 11-27-2014, 03:47 AM
Bought mine here they are doing their new customer promo again 15 % off
http://www.autoanything.com/performa...A5754A0A0.aspx
Free shipping
The Following User Says Thank You to Weld engineer For this addition to TDG:
Levi'sford (11-27-2014)
post #6 of 7 (permalink) Old 11-28-2014, 05:30 AM
Create an account at Advance Auto and use the code TRT30 (30% off).
The Black Friday code (M44) might also work.
You can get it for apprx. $115 plus shipping
http://shop.advanceautoparts.com/p/s...sg2/10206633-P
Edit - looks like AA is not taking the codes on the Scangauge right now (probably because it is currently on sale for $20 off), so it is $139.99 plus shipping
I bought mine through CleanMPG.com.
I joined their forum (free) and got in on their group buy for $135.
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD BilletWaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
bismic is offline
The Following User Says Thank You to bismic For this addition to TDG:
Weld engineer (11-28-2014)
post #7 of 7 (permalink) Old 11-28-2014, 06:01 AM
I am striking out tonight ..........
The Scangauge D was available using the TRT30 promo code ($111 free shipping), but then I saw that it does not have the proper OBDII connection.
Back to Weld's post for the best deal (until Advance Auto removes the $20 sale on it and we can use the TRT30 again).
Mark
bismic is offline
The Following 2 Users Say Thank You to bismic For this addition to TDG:
harry6.0 (11-28-2014), Weld engineer (11-28-2014)
No Starting and hard starting carchris 2003-2007 6.0L Power Stroke 3 04-11-2010 01:09 AM
Hard starting Borcht Warrior 2003-2007 6.0L Power Stroke 3 12-07-2009 01:22 AM
hard starting tugboat001 1994-2003 7.3L Power Stroke 8 03-20-2007 05:09 PM
hard starting STROKETHIS7.3 1994-2003 7.3L Power Stroke 2 11-08-2006 02:18 PM
hard starting and not starting fender 5.9L Cummins (2003-2007.5) 2 01-07-2006 07:27 AM
