6.0L block interchange - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TooManyToys, this thread has received 4 replies and been viewed 2118 times.
post #1 of 5 (permalink) Old 02-02-2015, 03:52 PM Thread Starter
Curmudgeon
TooManyToys's Avatar
Can a later long block such as an '06 be used in an '03 with the installation of the '03 intake, turbo, etc along with the harness modification to move the ICP connector over to the passenger valve cover?
Just thinking about the worst.
Jack -
Formerly FMTRVT, Manager of Vehicle Testing - Brakes
2003 F-350SC Lariat 4x4 6.0L Auto
Truck Modifications as below in Pictorials on Facebook. Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
TooManyToys is offline
post #2 of 5 (permalink) Old 02-03-2015, 12:48 AM
As far as I can remember the blocks are the same. It is the heads, rocker boxes, intake manifolds, turbo, egr cooler, hpop that changed. Look into the 6.0 bible there is a changes section by year if I recall.
lenzhotrod is offline
post #3 of 5 (permalink) Old 02-03-2015, 01:16 AM Thread Starter
Curmudgeon
Yep, got that. But if you have an '06 long block, with heads and everything under the valve covers, can the '03 turbo pedestal (and therefore turbo), intake manifold, EGR cooler all be utilized up on top of an '06. As far as I understand the only engine connection and control that is different is the ICP pressure sensor location. The only truly way to know is if someone tried it.
Jack -
post #4 of 5 (permalink) Old 02-03-2015, 04:39 AM
harry6.0's Avatar
I found this...
http://www.internationalpowerstroke....r-changes.html
But like you said, need to find someone thats been there.
Harry
harry6.0 is offline
dbennett48 (02-03-2015)
post #5 of 5 (permalink) Old 02-09-2015, 12:21 AM
Stuck in Commiefornia...
IdahoF350's Avatar
The only real issue/difference externally is the location of the ICP sender. Just make an extension harness from under the turbo to the passenger valve cover. The intake manifolds will interchange, just be sure to use the '03/Early-'04 stuff with '03/Early-'04 stuff and the Late-'04.5-07 with the Late-'04.5-07 when it comes to the intake elbow, intake manifold, EGR valve, EGR cooler, Up Pipes, Y-pipe, Turbo, and turbo pedestal.
Everything else should bolt up. The only other major difference with 6.0L engines is the rear covers on automatics and manuals, they use different rear covers for the different bell housing patterns.
Physically using an '06 engine in an '03 should be fine and not that difficult, it's the mixing and matching of internal and sub-assembly parts from early and late engines that will cause you grief.
Sent by my right thumb!
2000 Excursion XLT 4x4
IdahoF350 is offline
The Following 3 Users Say Thank You to IdahoF350 For this addition to TDG:
dbennett48 (02-09-2015), harry6.0 (02-10-2015), TooManyToys (02-11-2015)
6.2 C and J code interchange ?? trucknut6657 6.2L Diesel Engine 5 04-17-2011 10:18 AM
What 6.5 parts will interchange with a 6.2? Lonesome7.3 6.2L Diesel Engine 9 12-30-2008 05:41 AM
6.5/6.2 what will interchange? 116027 6.5L Diesel Engine 0 11-01-2007 01:54 AM
What years interchange? Diesel Dog General Dodge Discussion 8 07-02-2006 05:49 AM
04-06 part's interchange? DSI 2003-2007 6.0L Power Stroke 10 06-20-2006 07:09 AM
