03 6.0 discharge tube won't come off! Help! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bkeese, this thread has received 5 replies and been viewed 1098 times.
post #1 of 6 (permalink) Old 02-20-2015, 04:22 PM Thread Starter
I was hoping someone could chime in on this. I did a pressure test and found my discharge tube was leaking at the connector to the branch tubes. I took the tool and went to take it off and it won't come off! It moves out like 1/8 to 1/4 of an inch like it is coming off then nothing. It will not budge. I push it back and it feels like it clicks back in and then I do it again and same thing. Won't come off!! Could the o ring be broken and jamming up the mechanism?? Any suggestions on what to do???????? Please help its about to snow and it's my plow truck! Thanks
bkeese is offline
post #2 of 6 (permalink) Old 02-20-2015, 07:25 PM
Old Fart
dbennett48's Avatar
What "discharge tube" are you referring to? Not a normal term.
Dave
Completely Stock.
KK6TNI - HAM Radio
dbennett48 is offline
post #3 of 6 (permalink) Old 02-20-2015, 07:58 PM Thread Starter
The tube that connects to the top of the hoop and runs to the branch tubes on the 03 6.0
bkeese is offline
post #4 of 6 (permalink) Old 02-21-2015, 01:51 PM
harry6.0's Avatar
You probably already got it off by now, but this tool here can help if readily available...
http://www.amazon.com/OTC-6594-Line-...+oil+line+tool
Harry
harry6.0 is offline
dbennett48 (02-21-2015)
post #5 of 6 (permalink) Old 02-22-2015, 07:30 PM
robs97z28's Avatar
did you ever figure out what was wrong?
03 Excursion, Banks turbo back, K&N intake, 285/70R17 on Eagle alloys, purchased June '10
robs97z28 is offline
post #6 of 6 (permalink) Old 02-25-2015, 03:49 PM Thread Starter
Thanks for all the help, I finially got the discharge tube off. The groove was filled with what looked like melted o ring or at least dried sludge. Wouldn't allow the spring clip to go inside the groove to release it. Basically i used the tool I made and a screw driver to further put pressure on the plastic ring and then pulled and wiggled with all my might... Took me about 10 attempts but finally it let go ( and slammed my hand into the block when it let go) but I got it and replaced it and the truck is a live again, thanks for the help. I have the tool definitions if anyone wants them. I found a forum where someone posted them but it was for the later stc fitting and so I demeled it out until it fit
bkeese is offline
The Following User Says Thank You to bkeese For this addition to TDG:
harry6.0 (02-26-2015)
HPOP Discharge Line Removal Fixinitmyself 2003-2007 6.0L Power Stroke 5 05-01-2013 07:47 PM
a/c oriface tube?? ccobra70 1994-2003 7.3L Power Stroke 10 06-12-2010 02:42 PM
IC Tube!!! bluovldeezl Whats Been Sold 4 05-31-2009 04:19 PM
Tq tube Steve Le Doux 5.9L Cummins (2003-2007.5) 0 01-01-2007 04:08 AM
I won, I won,wooo-hooo I won nummit The Parking Lot 2 03-07-2006 04:25 PM
