p0118 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by budwagon1274, this thread has received 2 replies and been viewed 1076 times.
post #1 of 3 (permalink) Old 03-01-2015, 06:33 PM Thread Starter
budwagon1274's Avatar
p0118
hey guys my cel came on today after I sprayed degreaser on the engine and hosed it off my scan gauge is showing p0118 any thoughts... thanks in advance
budwagon1274 is offline
post #2 of 3 (permalink) Old 03-01-2015, 07:33 PM
harry6.0's Avatar
I believe thats a coolant temp sensor fault code.
Maybe from spraying the engine it cooled the sensor too quickly or got water on the contacts.
Make sure your coolant temp reads normal values on your scangauge first, if all ok, then...
Clear the fault code, and if comes back on again later, then check or clean the connector wire-contacts on the coolant temp sensor, or you may possibly need to replace the sensor if it's malfunctioning.
Harry
harry6.0 is offline
budwagon1274 (03-01-2015)
post #3 of 3 (permalink) Old 03-01-2015, 08:02 PM Thread Starter
that's what it was temps are fine kept clearing code but it came back I unhooked the batts for a bit and its gone now not throwing any codes now I think is the connections were wet messing with it but all is good now
The Following User Says Thank You to budwagon1274 For this addition to TDG:
Weld engineer (03-02-2015)
P0118 taco_style 2003-2007 6.0L Power Stroke 2 10-02-2007 12:07 AM
