coolant loss - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Robts, this thread has received 4 replies and been viewed 1134 times.
post #1 of 5 (permalink) Old 05-02-2006, 02:14 AM Thread Starter
Robts's Avatar
coolant loss
On my home from up north I lost about a gallon and a half of coolant. How can i tell if its the headgasket or the egr valve stuck open
2004F-SVT Lariat 2005 Cummins 5.9 conversion
August 2007 TDG Truck of the Month
Septmeber 2009 TDG Truck of the Month
2008 TDG Truck of the Year
2005 CR Cummins conversion with destroked motor mounts and tach module.
ARP Studs;Hamilton springs and pushrods
WickedDiesel DragonSlayer CP3 and 5x10.5 inj
Tsperformance MP8; Smarty S06 TNT-R
Speraco Inercooler; Opie Water by-pass;DTT intake elbow
Twin turbos
Grand rock 7" stacks
ATS Stage V 48re Transmission with billet output shaft and Co-pilot
Ford transfer case with ATS input shaft. Thanks to Sogrand for that
4.56 gears with Detroit truetrac. Custom Oasis Diff covers
FarmboyFabrication Ladder bars
(10) Autometer Gauges
6.5" Explorer Procomp lift with Fox Shox
37x13.5x22 Toyos with 22x10 Eagle wheels
2005 front end conversion with McColluch HID lights
Randy Ellias light bar with 4 procomp 130watt lights
Heat exchanger hood; limo tint, recon lights up top and on the mirrors
Optima. Yellow Tops; BilletBadges; Big special thanks to Walley at FTE
My Cummins conversion:https://www.thedieselgarage.com/foru...read.php?t=933
Robts is offline
post #2 of 5 (permalink) Old 05-02-2006, 02:23 AM
Destroked
diesel dan's Avatar
Is it leaking out the resoviour tank or underneath the truck, or not at all?
diesel dan is offline
post #3 of 5 (permalink) Old 05-02-2006, 02:29 AM Thread Starter
Robts's Avatar
Its not leaking at all.
I was running hard on the way home. I was pulling a 7x12 classic enclosed trailer with Jason program race with tq lock up at 80 mph. Thats about 25 lbs psi all the way home
Twin turbos
Robts is offline
post #4 of 5 (permalink) Old 05-02-2006, 02:37 AM
Destroked
diesel dan's Avatar
Sounds like you lost a gasket then......Its probably burning the water.
post #5 of 5 (permalink) Old 05-02-2006, 03:02 AM
fordt
There should be some white spots, the coolant residue somewhere on your motor or around the resovoir tank, if it's just the cap that failed. Where was the top of the coolant at when you started the trip? Was it filled to the top?
