coolant loss - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Robts, this thread has received 2 replies and been viewed 1095 times.
post #1 of 3 (permalink) Old 05-13-2006, 04:43 AM Thread Starter
Robts's Avatar
coolant loss
Im not really sure if my head gasket is gone. A diesel machinac told me it may be my egr cooler. I dont have a lose of power but a lose of collant. How do I know what it is.
please help. Truck sitting in driveway and need to go fast
2004F-SVT Lariat 2005 Cummins 5.9 conversion
August 2007 TDG Truck of the Month
Septmeber 2009 TDG Truck of the Month
2008 TDG Truck of the Year
2005 CR Cummins conversion with destroked motor mounts and tach module.
ARP Studs;Hamilton springs and pushrods
WickedDiesel DragonSlayer CP3 and 5x10.5 inj
Tsperformance MP8; Smarty S06 TNT-R
Speraco Inercooler; Opie Water by-pass;DTT intake elbow
Twin turbos
Grand rock 7" stacks
ATS Stage V 48re Transmission with billet output shaft and Co-pilot
Ford transfer case with ATS input shaft. Thanks to Sogrand for that
4.56 gears with Detroit truetrac. Custom Oasis Diff covers
FarmboyFabrication Ladder bars
(10) Autometer Gauges
6.5" Explorer Procomp lift with Fox Shox
37x13.5x22 Toyos with 22x10 Eagle wheels
2005 front end conversion with McColluch HID lights
Randy Ellias light bar with 4 procomp 130watt lights
Heat exchanger hood; limo tint, recon lights up top and on the mirrors
Optima. Yellow Tops; BilletBadges; Big special thanks to Walley at FTE
My Cummins conversion:https://www.thedieselgarage.com/foru...read.php?t=933
Robts is offline
post #2 of 3 (permalink) Old 05-13-2006, 05:43 AM
have your machanic pressure up the coolant system. take the egr valve out and look & listen for the leak. i have had to go as high as 20 psi to hear it leaking. if it is the egr? does the truck smoke white hot or cold?? coolant leaking into the egr track will be easy to see. your machanic should have a combustion gas tester? this will tell you if it is a head gasket. do you or your machanic have a way to put a vacume on the coolant system,if so do it, pull the intake tube off where it goes into the elbo of the intake. put your hand over the hole on the elbo,pull vacume now take your hand off did the vacume go to zero if yes its your egr, if not you need to do more tests and it may be a head gasket?
imported_diesel71 is offline
post #3 of 3 (permalink) Old 05-13-2006, 06:49 AM
Problem with the combustion gas tester is that every single 6.0L will pump some combustion into the coolant on startup. So it will turn slightly green. But if it is super green you know you have combustion gas there. I posted the TSB for the coolant loss in the tech forum. If you disconnect the EGR valve with the engine off and run the truck and the coolant loss is less, then it would lead you more toward the cooler.
PSDPlayer is offline
