P0261 P0267 P0273 P0279 P0282 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Smoker, this thread has received 11 replies and been viewed 1561 times.
 1Likes
post #1 of 12 (permalink) Old 06-22-2016, 03:04 AM Thread Starter
Smoker's Avatar
Going to work this AM and halfway there (2 miles) the engine light came on. Got home and read the above codes with my SCT. All imply a Injector Circuit Low. The truck ran great the rest of the way to work and home.
I did some research and read several posts about poor/weak batteries, alternator issues, or FICM. I removed the FICM, checked all the various connectors in the general area, looked for chafed wires, etc. Installed the FICM making sure all three connector fully seated and heard two snaps (front and read clip) for each connector. I checked battery voltage and it was ~12.5v but was not able to do a load test like bismic suggested in another post. I'll need to take them somewhere for that.
Just for the hell of it I put the trickle charger on it this evening.
Nothings been done to the truck for a few years except regular PM - it's been running great. I just turned over 34,000 miles so I would doubt it's the FICM but I know crap happens.
Any ideas of things to check or have you seen this?
Bill
2006 SD250CC 4WD Lariat, CAT Delete, Coolant Filter, Fuel Crossover, SCT TSX with EGT sensor, ARP Studded, Custom Flow tailgate, Autometer FPG, Bulley Dog bed steps, '08 diff cover with Amsoil 75w140, Blue spring mod, Stempede hood shield, PCV mod, full EGR cooler removal/delete, Rhino bed liner, tunes, Rotella ELC, Doodad mod, Archoil AR6200 with 2-stroke, 185A Alternator, FS F2400 airbags, SumoSprings front axle, 6.4 Trany pan and filter.
Smoker is offline
post #2 of 12 (permalink) Old 06-23-2016, 03:04 AM Thread Starter
Smoker's Avatar
After a night on the charger I cleared the codes this morning. Nothing happened on the drive to work but going home they came up again, this time a couple more than yesterday but all still relating to injector circuit low.
Alt is putting out ~14.1v. Battery load test was good.
Based on what I'm reading it's sounding like the FICM. I need to check it's voltage output next.
Smoker is offline
post #3 of 12 (permalink) Old 06-24-2016, 02:12 AM Thread Starter
Smoker's Avatar
Took the V output on the FICM:
Key on Eng off: 48.4 - 48.6
During Buzz test: 45.3 - 46
Engine on: 25-26
Already pulled it out. Just over 1000 hours on it.
I'll need to get one overnighted for Monday. Anyone have a recommended placed to get one?
Bill
Smoker is offline
post #4 of 12 (permalink) Old 06-24-2016, 04:38 AM
harry6.0's Avatar
FICM is toast for sure, ficm powerboard voltage converter half shell is now available from any Ford dealer, just swap it out with the new improved half shell and your good to go, no programming needed.
As I mentioned in my PM to you, and alot of us on here knew Dieseltech Ron from ebay who repaired many ficm's including my own spare that I carry. Was killed last May in an unfortunate car accident on his way to work early in the morning, here's a link to his last video that his son did...very very sad...https://www.youtube.com/watch?v=_43Gs63Bsqk
God Bless Ron for all his help to the diesel community.
Harry
harry6.0 is offline
Smoker (06-27-2016)
post #5 of 12 (permalink) Old 06-24-2016, 04:43 AM
harry6.0's Avatar
Sorry, didn't mean to partially hijack your thread, but when FICM came to mind I couldn't help but think about Ron.
Harry
harry6.0 is offline
post #6 of 12 (permalink) Old 06-27-2016, 03:28 AM Thread Starter
Smoker's Avatar
Ron was an outstanding person. You could tell he had a heartfelt desire to share his skill with the diesel community.
As you noted above about the half shell I did order one - should arrive Wednesday. None of the local shops had one. Thanks for the idea.
I hope the PS was the only thing wrong with it.
Cheers
Bill
Smoker is offline
The Following User Says Thank You to Smoker For this addition to TDG:
harry6.0 (06-28-2016)
post #7 of 12 (permalink) Old 06-28-2016, 05:37 AM
harry6.0's Avatar
I'm 99.9% sure the new ficm halfshell will fix your problem.
And yeah, Ron was a great guy.
Harry
harry6.0 is offline
post #8 of 12 (permalink) Old 07-13-2016, 02:26 AM Thread Starter
Smoker's Avatar
Got the half shell made by TechSmart in from BPD and we're up and running. Getting ~48.4v at 2k. At the same time I installed a more robust alternator from DC Power. I keep a cheap-o battery and charging system monitor in the cig lighter. After the alt install the charging readout went from about 13.4-13.6v to just over 14v.
Hooked up the 5vr over the holiday for a week of camp; it ran like a champ.
ID:	39834   Click image for larger version
Smoker is offline
harry6.0 (07-13-2016)
post #9 of 12 (permalink) Old 07-13-2016, 02:01 PM
harry6.0's Avatar
Thanks for the followup Bill! Glad your up and running.
That half-shell looks to be good quality, especially like the made in USA part. Alternator looks good too. What is the alternator amperage rating?
Harry
harry6.0 is offline
post #10 of 12 (permalink) Old 07-14-2016, 06:51 PM Thread Starter
Smoker's Avatar
Harry -I got the DCP 185A (spec at cold) unit from FICMrepair. This is a 68% amp increase over OEM. I don't need anything larger for what I do. Speaking to DC Power I was told they spec this unit at 100A idle hot (200F) and 150A max hot. Whereas the most I could find out on-line and calling Ford the OEM unit put out 60A max hot.
I don't run with gel batteries so the 14.8v spec output is fine.
Two good improvements I've been able to quantify at this point is idle voltage immediately after starting when the glow plugs are on is a min of +1v increase. I was seeing mid to low 11s with OEM. Normal operating voltage has also increased about 1v. Running AC, stereo and the 5vr the change is almost negligible.
Bill
harry6.0 likes this.
Smoker is offline
harry6.0 (07-17-2016)
P0273 jbird 2003-2007 6.0L Power Stroke 3 05-29-2009 02:31 AM
