06 f250 no power when pulling trailer - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ranger518, this thread has received 5 replies and been viewed 925 times.
post #1 of 6 (permalink) Old 08-22-2017, 09:48 PM Thread Starter
ranger518's Avatar
My truck has been running great but today when I went to pull my gooseneck trailer 15k it would not pull it at all felt like I was dragging it by it axles and would not go over 60 Mph. EGT were high 1,100 ECT was 220 EOT was 210 fuel pressure 68. Not sure what is going on any ideas?
I think it is great that Cummings service trucks are f-550 with 6.0 and 6.4. They must know somthing?
2006 F-250 lariat FX4
4" turbo back MBRP stainless steel exhaust cat delete
Airaide intake
Homemade coolant filter
Custom oil bypass filter
Quad pillar gauges EOT, ECT, Fuel pressure, and EGT
RCD EGR kit with new up pipe
Blue Ford fuel spring went form 45psi to 68psi part number 3C3Z-9T517-AG
Rancho Rs9000 shocks with my ride controll
Homemade 3" lift
315x70x17 BFG AT's
SCT With custom Innovative tunes
Mobil ELC Cat-1 Coolant
2004 Turbo
Zoodad mod
ranger518 is offline
The Following User Says Thank You to ranger518 For this addition to TDG:
wds13196 (11-06-2017)
post #2 of 6 (permalink) Old 08-24-2017, 04:33 AM
Turbo boot popped off? Well, if that happened you wouldn't make it to 60 mph.
Turbo vanes stuck? What boost are you making?
Maybe IPR/ICP?
2005-6L/PSD F-250 Lariat CC/SB/4x4:
- MBRP 4" turbo back, Dieselsite coolant bypass filter, Frantz oil bypass filter, X-monitor, Fluidampr, fuel x-over line, intake elbow, EGR cooler delete, wrapped headers and turbo, ARP studs, OEM gaskets, ported heads and manifolds to match, Hot FICM w/ ID Flash, 08+ tranny pan/filter.
pstrang is offline
post #3 of 6 (permalink) Old 08-27-2017, 01:30 PM
Also, your temperature readings are off. Oil temperature will always be higher than coolant temperatures after the engine is fully warmed up.
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD BilletWaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
bismic is offline
post #4 of 6 (permalink) Old 08-30-2017, 03:51 AM
harry6.0's Avatar
Any excessive black smoke? If so, I would suspect a turbo issue, check your air filter first.
Harry
harry6.0 is offline
post #5 of 6 (permalink) Old 09-02-2017, 01:55 AM
I'm sorry but I have to do this...did you check to see if your foot was on the brake? ...I'm mentioning this cause I had a coworker that was always burning up brakes and I noticed his break lights seldom went off. I brought this to his attention and he became irate saying he would never do such a thing. Well it wasn't long after that incident before he received a ticket which i'm sure saved him a bundle in brake repairs over time
2007 F250 6.0PSD CC SB 4X4 Lariet stock
1975 Ford 2000 D tractor
bfloyd4445 is offline
post #6 of 6 (permalink) Old 09-03-2017, 01:47 PM
harry6.0's Avatar
Brakes stuck on is a possibility, like from a faulty master cylinder, but I doubt he's riding the brakes.
Harry
harry6.0 is offline
2001 dodge Overheating when pulling trailer RachelJeanWalker 5.9L Cummins (1998.5-2002) 4 06-22-2014 02:32 AM
pulling an air brake trailer with my truck, I need the hook up dondiesel444 Medium and Heavy Duty 24 07-31-2013 08:01 PM
Dash shakes/vibrates when pulling trailer honda_guy4 2008-2010 Body & Suspension 5 05-03-2010 01:08 AM
Pulling a 5th Wheel Travel Trailer Question UT CUMMINGS 5.9L Cummins (2003-2007.5) 14 04-19-2008 04:04 AM
Manual Tranny temp pulling travel trailer GOPDiesel 2003-2007 6.0L Power Stroke 7 03-24-2008 09:09 PM
