04 6.0 air filter light - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Hicks1009, this thread has received 3 replies and been viewed 462 times.
post #1 of 4 (permalink) Old 03-13-2018, 04:27 AM Thread Starter
Air filter light came on yesterday and won't reset. Filter and minder only month old. If I unplugged electrical from minder light went out. Plugged in and light came on again. Noticed a little moisture in plug. Blew it out but still on. Can I leave electrical unplugged without messing anything up? Thanks in advance.
Hicks1009 is offline
post #2 of 4 (permalink) Old 03-13-2018, 06:06 PM
Are you using an OEM filter and an OEM filter-minder, or did you purchase aftermarket parts?
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD BilletWaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
bismic is offline
post #3 of 4 (permalink) Old 03-14-2018, 01:30 AM Thread Starter
Yes oem on both
post #4 of 4 (permalink) Old 03-14-2018, 05:27 PM
I guess I would leave it unplugged, just make sure that the harness wiring isn't damaged and shorting out. I can't imagine running it unplugged would be an issue.
Mark
bismic is offline
Air filter light Hicks1009 Introductions 0 03-13-2018 01:44 AM
Air Filter Light? codyr6 2003-2007 6.0L Power Stroke 4 03-14-2010 04:02 PM
engine air filter light circle5 2003-2007 6.0L Power Stroke 2 01-06-2010 09:47 PM
Air Filter Light On ChiefMC 2003-2007 6.0L Power Stroke 5 11-07-2007 03:24 PM
So my air filter light came on EJ Krueger General Ford Truck and Excursion 3 05-22-2006 06:40 PM
