Purging air from fuel system - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by MattBMiller, this thread has received 9 replies and been viewed 1543 times.
post #1 of 10 (permalink) Old 06-14-2006, 05:57 PM Thread Starter
Anyone else have trouble with the 05-06's with air in the fuel system after filter changes? I have two buddies with 05's that their trucks will not start without letting the fuel pump run for two key cycles for a couple weeks after a filter change. I just changed the filters in my 06 again and have this same thing now. Never had this problem on my 03. O-rings on both filters are fine. Anyone else have this happen?
Matt
MattBMiller is offline
post #2 of 10 (permalink) Old 06-14-2006, 08:38 PM
My 7 year old son and I just changed the filters in my 05...I did several key cycles before starting the truck...no problems...start's fine...
05TowBoss is offline
post #3 of 10 (permalink) Old 06-14-2006, 08:43 PM
after a filter change you need to cycle the key on for 20 seconds then off. do this 3 times.
imported_diesel71 is offline
post #4 of 10 (permalink) Old 06-14-2006, 09:26 PM
Perhaps you have an 03-04 filter in an 05 truck? I read that there was a change in the fuel filter cap that would not allow it to seat properly with the old filter. Did you check the o ring?
nummit is offline
post #5 of 10 (permalink) Old 06-15-2006, 01:37 PM Thread Starter
Are there new filters for 05/06's? I did notice the fuel filter lid is different than on the 03/04's. I believe it is the same as the oil filter lid... O-rings are fine.
Matt
post #6 of 10 (permalink) Old 06-15-2006, 03:12 PM
Matt
I am pretty sure there is :shrug: I will search around
nummit is offline
post #7 of 10 (permalink) Old 06-15-2006, 03:22 PM
I don't know what brand of filter you are using but there was a change, atleast for wix.
https://www.thedieselgarage.com/forum...t=fuel+filters
nummit is offline
post #8 of 10 (permalink) Old 06-15-2006, 05:09 PM Thread Starter
That's interesting...I used a Motorcraft filter. The book only had 1 part number for the 6.0's though...
Matt
post #9 of 10 (permalink) Old 06-15-2006, 06:02 PM
Texas XC Quad Racer
I believe they only have one part number, and with that part number, you'll get a box with two filters and two seals.
sredish is offline
post #10 of 10 (permalink) Old 06-15-2006, 06:54 PM
Matt
Motorcraft knew the lid was changing wix did not..so the ford one will fit both wear as the wix needs two different ones.,,now that said make sure you look down in the fuel bowl cause the inner flange of the old fuel filter can stay on the post and the new one will go on just not seal right....I will try to post a pic latter with what Im talking about....
j.schall
jschall is offline
