Removing Flex Pipe on Up-Pipe and Y Pipe - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hhrecovery, this thread has received 27 replies and been viewed 12244 times.
post #1 of 28 (permalink) Old 11-27-2006, 10:30 PM Thread Starter
MAFIA #8
hhrecovery's Avatar
Images: 1
Has anyone completely removed all the flex pipe both on the Y pipe and the up-pipe since this seems to be a problematic area on these trucks. :Thumbup:
2003 F250 "Pulling Truck"
hhrecovery is offline
post #2 of 28 (permalink) Old 11-28-2006, 02:39 AM Thread Starter
MAFIA #8
hhrecovery's Avatar
Images: 1
Could this be done w/out any ill effects???
What exactly is the flex pipe in there for???
post #3 of 28 (permalink) Old 11-28-2006, 02:47 AM
i am sure you could get away without it, but i don't know, i am sure it's in there to either alow for expansion when it gets hot or so the lil movement doesn't crack the pipes over time
robert
alldiesels is offline
post #4 of 28 (permalink) Old 11-28-2006, 02:54 AM
powerstrokes rule
if you remove the flex pipes completly you will find the pipes will start to crack, the up pipes need the expansion joint for that reason, for expansion.
2003 F-350 crew cab 4X4 6 leaker
a few mods
[email protected]
redneck6.0l is offline
post #5 of 28 (permalink) Old 11-28-2006, 03:00 AM
Old Geezer-TDG Mafia #19
LargeCar's Avatar
Images: 9
Without the flex pipe and with the different expansion rates of dis-similar metals I am pretty sure the stress created would not be of advantage. Possible damage would be a high risk factor.
With the being said, I do beleive you might get by with some stainless steel pipes with slip joints, that is one pipe belled out so the other would fit snuggly inside it. Two problems come to mind in a flash, leakage and corrosion inside the slip joint. We used to make headers for race cars in section that could be installed a section at a time, each slip joint had a tab welded to each of the two pipes in the joint that would match up and be drilled for a bolt and nut as a fastening device.
LargeCar :mafia
LargeCar
Mafia # 19 The Dually Club # 19
If a country does not remember and honor its fallen heroes of the past, in the future that country will not be honored or remembered.
G.R. Wemmer
A veteran is someone who, at one point in his/her life wrote a blank check made payable to 'The United States of America' for an amount of 'up to and including their life.' That is Honor, and there are way too many people in this country who no longer understand it.
LargeCar is offline
post #6 of 28 (permalink) Old 11-28-2006, 03:16 AM
Still kickin
Flopster843's Avatar
What if the slip-joint idea was coated with something to prevent rust (powercoat or something) and then had a larger expansion joint welded over the top. You would still have the smooth transition(spelling) of a slip joint and would have the pressure seal of the expansion joint. We use a simalar design on the aircraft called a "wiggins coupling". We use rubber o-rings so that wouldn't work for the up pipes, but works great for our oil and fuel. And as most of you probably know, these jets flex a lot and they never break.
John
08 6.7 QC SB 4x4 "hand-shaker" edition, De-Badged, EGR Delete, TTT Mirrors, Auto Exhaust Brake, etc.
All details and instructions --> www.CarboniteCummins.com
Successfully blew up three 6.0s before moving up in the food chain.
Flopster843 is offline
post #7 of 28 (permalink) Old 11-28-2006, 06:56 AM
Diesel Pro
we could use headers, like the set available for the 7.3
http://www.truckblog.com/gallery/photo-20627/
2006 Dodge 2500 2wd QC SB 5.9 Cummins, 48RE Auto, 4" Exhaust, TS MPD W/HUD, Airaid Intake, 6k HIDs, GoGo Built Tranny, BDTD with Crazy Larry
13.85 @ 99 MPH
BFD99 is offline
post #8 of 28 (permalink) Old 11-28-2006, 07:00 AM
Diesel Innovations makes real nice steel braided flex-jointed up-pipes for the 7.3, perhaps Dave could be convinced to have some built for the 6.0?
LINKY FOR PICS :
BONE STOCK
444turbodiesel is offline
post #9 of 28 (permalink) Old 11-28-2006, 07:03 AM
moose99psd's Avatar
Originally Posted by banksforddiesel99
there is a set of prototype headers out.............. ive seen pics
yea well ive seen pics of christina augulaira, britney spears, among others naked... dosent mean they were REAL!
moose99psd is offline
post #10 of 28 (permalink) Old 11-28-2006, 07:13 AM
Diesel Pro
nick huh?
13.85 @ 99 MPH
BFD99 is offline
