Something interesting - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by partsguy662, this thread has received 7 replies and been viewed 1030 times.
post #1 of 8 (permalink) Old 06-29-2005, 06:27 PM Thread Starter
Rodney Dangerfield of TG
Send a message via AIM to partsguy662 Send a message via Yahoo to partsguy662
(Then again, it might only be interesting to me :blah: )
I was paging through my new Napa flyer this morning and I see that we are now offering a new air filter assembly to replace the stock unit. Apparently the stock air filter is a real project to change? At any rate, with this new setup, it is supposed to only take about 5 minutes to change a filter rather than 45 minutes.
Might be worth looking into if you're a 6.0 owner that isn't looking to put a high-performance air cleaner on your truck...
When I get the price of the kit and the replacement element, I'll post them. :Thumbup:
partsguy662 is offline
post #2 of 8 (permalink) Old 06-29-2005, 06:32 PM
I have replaced the stocker in mine... But i do not see that it would be hard to replace.. Very expensive, but not hard... You just replace the whole center section... 6 snap cleats... It took me less than 45 minutes to install the new intake...
If anyone is looking i have a replacement element that is high performance made by airaid, and I also have a airaid complete intake system...
NMU98 is offline
post #3 of 8 (permalink) Old 06-29-2005, 06:46 PM Thread Starter
I'm assuming that the flat rate time is 45 minutes, Brian...They guy/gal that did this write up has probably never seen a 6.0, much less worked on one
post #4 of 8 (permalink) Old 06-29-2005, 09:50 PM
Replacing the intakes on these things aren't neccesarilly hard just can be a knuckle buster compared to your normal filter. I wish we had air filters like the new 3V F150's issed: 2 clips and it slides out. issed:
biavaperformance is offline
post #5 of 8 (permalink) Old 06-29-2005, 10:13 PM
143 MPH Smoke Machine
I found a 16" pry bar really helped changing mine. issed:
The Fat Rabbit: 2005 TDI Passat loaded GLS, Custom Rocketchip, Hybrid GT17/22V Turbo, Beta KermaTDI FMIC, Kerma Race Injectors, fuel cooler, Garmin 2620, Uniden BC246T, Avon Tech M550 A/S and Starmate Replay.
Still the fastest TDI Passat in the Western Hemisphere by far thanks to Rocketchip and KermaTDI.:Thumbup:
TooMuchBoost is offline
post #6 of 8 (permalink) Old 06-29-2005, 10:46 PM Thread Starter
Looking at this kit, that's what they are attempting to do I think....4 clips top comes off and you put a filter in..
post #7 of 8 (permalink) Old 06-29-2005, 11:59 PM
Banned
Mine was a bit more stubborn, I had to pull out a 15lb maul I had lying around... Came off in a flash! issed:
j/k... My AirAid if you look under my sig and go to my gallery, and look at the filter, All you need is a flat screwdriver, and it just comes out for cleaning. :Thumbup:
-X
Choke_On_My_Smoke is offline
post #8 of 8 (permalink) Old 07-08-2005, 06:25 PM Thread Starter
Well, I finally got the pricing info for this kit...Looks like regular walkin price will be ~150 bucks....
If you know someone that has a fleet account with napa, you should be able to purchase it for around 100....
Scott
Wrong oil? zeddy 2008-2010 6.4L Power Stroke 13 01-02-2009 02:39 PM
Aftermarket Dodge bumper....pic TANK'S 250 The Parking Lot 38 12-26-2008 12:57 AM
got truck stats? nevrenufhp Medium and Heavy Duty 67 01-10-2006 11:37 PM
Newbie checking in BigBadDodge Sled Pulling 10 08-19-2005 04:15 AM
Franchise ob1kobi The Parking Lot 4 06-07-2005 02:43 PM
