Best place to tap an oil supply - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by LargeCar, this thread has received 5 replies and been viewed 833 times.
post #1 of 6 (permalink) Old 04-16-2007, 10:16 PM Thread Starter
Old Geezer-TDG Mafia #19
LargeCar's Avatar
Images: 9
Putting a bypass filter on soon and was wondering if anybody has used the Oil Pressure Test Port that in in the picture on page 24 of the 6.0 bible?
Or would you just tee off of the Oil Pressure Switch which in the picture on page 25 of the 6.0 bible?
Thanks
LargeCar :mafia
LargeCar
Mafia # 19 The Dually Club # 19
If a country does not remember and honor its fallen heroes of the past, in the future that country will not be honored or remembered.
G.R. Wemmer
A veteran is someone who, at one point in his/her life wrote a blank check made payable to 'The United States of America' for an amount of 'up to and including their life.' That is Honor, and there are way too many people in this country who no longer understand it.
LargeCar is offline
post #2 of 6 (permalink) Old 04-16-2007, 10:24 PM
I be Architect'n
If that's the one just above the oil filter then yes, I have my 7.3 supply and return right there. I actually used the Oilguard website install because I liked it better than Amsoil's recommended installation.
2K3 EXCURSION 7.3L 4x4 EDDIE BAUER 107K miles as of 06-13-07
AFE Stage II / 4" MBRP exhaust / DP-Tuner F5 (Stock, 60hp Tow, 80hp Econo, 120hp race & High Idle) / Quadzilla Commander/ATS Housing
Running homebrewed BioDiesel and custom SVO kit for 70k miles.:Thumbup:
Misc. Mods: ZooDad/By-Pass Oil Filter/203* T-Stat/Coolant Filter/HPX/CCV Reroute/Tranny Filter/Foil Delete/Stereo Stuff/ITP Reg Return/Non-EBPV Pedistal and Exhaust Housing/Adjustable Waste Gate Controller/
"If you love your motorcycle, set it free. If it comes back to you it was probably a high-side."
I'LL TRY TO KEEP UP, BUT THE EXCURSION IS A BIG GIRL AND BIG GIRLS DON'T LIKE TO MOVE FAST.
6_Myles is offline
post #3 of 6 (permalink) Old 04-16-2007, 11:01 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
Large, why dont you just run off the top of the oil filter housing... Get you a billet cab that is already tapped for a good price from DJs Performance OR I will send you my stock cap and you can see if you can drill and tap it...
2003 F250 "Pulling Truck"
hhrecovery is offline
post #4 of 6 (permalink) Old 04-16-2007, 11:16 PM Thread Starter
LargeCar's Avatar
Images: 9
I would rather not have a connector and hose hanging off the top of the filter cap. After looking some more at the project and the bible I guess the oil test port is pretty buried, so that leaves the EOT and the EOP switches to tee off of.
LargeCar :mafia
LargeCar
G.R. Wemmer
LargeCar is offline
post #5 of 6 (permalink) Old 04-17-2007, 04:57 AM
LargeCar, I'm with you on this one. I'm about to complete the plumbing on the same install but didn't like the idea of coming off of the filter cap even though I have one that I'm not going to use.
The test port does look buried down there and I was also looking at the the oil press sensor for a by pass feed and a pressure feed for my guage.
For the return, I bought an oil fill billet cap on ebay and a swivel fitting from amsoil.
Just a matter of getting the plumbing fittings the right size. I don't know if the pressure sensor fitting is imperial or metric. Perhaps someone knows the fitting size. I believe amsoil piping has 1/8" fittings.
I mounted my filter on the only space available on the pass. side beside the rad. I looked at mounting it where HHRECOVERY had his but didn't like my odds of the filter case getting hit from the axel or rocks.
I mounted my coolant filter on the frame rail below the power brake booster and out of the way of the front drive shaft. There's not a lot of options where to mount the aux filters on this truck.
04 f350, 6.0l psd
banks intercooler, afe intake, zoodad, egr block, fuel x over line, fluidamper , gutter mod, coolant filter, amsoil bypass filter, quad gauge pod with autometer guages, bilsteins
BCFlyfisher is offline
post #6 of 6 (permalink) Old 04-17-2007, 05:23 AM Thread Starter
LargeCar's Avatar
Images: 9
I hope I can get a see through gas filter and take the filter out of it just to use it as a sight glass on the return side. I think I will drill and tap the filler tube as low as I can get one of the hex flats to screw in a return line. I think I will use AN 4 stuff. Still putting together the pieces.
LargeCar :mafia
LargeCar
G.R. Wemmer
LargeCar is offline
