I need F-350 rear blocks and u-bolts - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 1badsixohh, this thread has received 7 replies and been viewed 1047 times.
post #1 of 8 (permalink) Old 06-26-2007, 07:39 PM Thread Starter
Hey everyone, i am looking for a set of F-350 rear blocks and u bolts for my truck, I recently just got my x-cal 2 from ID(those guys rock) and today i went and got a set of brand new toyo open country at's 325/65R18, i also got a leveling kit for the front so now i just need the rear block and u- bolts and ill be set for awhile! Also i have the top mount over load springs! Any help you guys can give me would be great. thanks!!!
1badsixohh is offline
post #2 of 8 (permalink) Old 06-27-2007, 05:26 AM
won't it sit nose down with f350 blocks?
2003 6.0 f250 ccsb 4x4 auto
Darsey715 is offline
post #3 of 8 (permalink) Old 06-27-2007, 08:01 AM
G SQRD's Avatar
If your installing a 2.5" leveling kit and swap in the F350 blocks it will sit slightly nose down like from the factory. When you hook up to decent size trailer it will level itself out. This is what I'm planning for my truck. I just ordered factory blocks and U-bolts for about $150.
2006 F-250 Amarillo Crew Cab "The Pineapple Express"
Tinted Front Windows, B&W Goose Neck Hitch, Dfuser coolant filter, Van Aaken Monitor, 4" MBRP Turbo Back Exhaust, SCT tunes by Elite and DJ, 4.5" DR lift, Raceline Renegade 8's and 35x13.50 Cooper STT's....Next: 4.30 gears and ARB locker front and rear.
1985 GMC 1500 4x4 6.2L Diesel "The white Stallion" 340k miles, still blowing smoke and won't die!
G SQRD is offline
post #4 of 8 (permalink) Old 06-27-2007, 12:29 PM
It will not sit nose down. If you use a leveling kit in the front and 350 rear blocks instead of 250 blocks it will sit like a stock 250 just higher. Trust me, this is what I have on my truck. It works good and with the right wheel it will clear 35's with no issues.
jeffro is offline
post #5 of 8 (permalink) Old 06-27-2007, 02:08 PM
The DUDE!!
sprman's Avatar
Which level kit are you using? I have that same size and i'm still on stock but i am thinking of doing the level kit w/blocks, but stil debating.
2005 F-250 CC FX4 - bought it, changed some stuff
Eighty Sixed member - #3
Ridin' Dirty - #26
"All the oil is in TEXAS, but the dipsticks are in DC"
"If Obama is the answer, it must have been a stupid a** question......"
sprman is offline
post #6 of 8 (permalink) Old 06-27-2007, 06:11 PM
I used Super Lift front coil spacers and 350 rear blocks.
jeffro is offline
post #7 of 8 (permalink) Old 06-28-2007, 09:03 PM
G SQRD's Avatar
Doesn't a stock 250 and 350 sit slightly nose down from the factory? :shrug:
G SQRD is offline
post #8 of 8 (permalink) Old 06-29-2007, 01:19 AM
i have blocks u bolts and shocks if your interested, also the 250 and 350 sit slightly nose down from the factory and when you level a 250 its higher in front due to the 2 1/4" block in rear and the 350 sits level it has a 4inch block in rear
imported_powerstrokebronco is offline
