Fuel System? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BVavra, this thread has received 81 replies and been viewed 6726 times.
post #1 of 82 (permalink) Old 07-05-2007, 01:18 AM Thread Starter
Fuel System?
I have 06 F-250 with 4.5" lift and 35's, SCT from DJ, gauges and 4" exhaust; will a fuel system give me any extra power or fuel milage without injectors? I want a system that will look good under the hood also. I have looked at elite's stage 1, LIPD's stage 1, and DJ's fuel intensifyer. I like the look of LIPD's the best, but it is not just for looks. I am sure they all work very well but what would the for my set up? If i keep the truck long enough I may get injectors but not anytime soon. Please help me make a decision.
2006 Crew Cab SB F-250 FX4 King Ranch Dark Copper, every option!! DR 4.5" lift with rear add-a-leaf and 5" blocks, Toyo MT 35x12.50, Weld Rubicon Volt 8 Chrome 18x10, DR dual steering stabs mounted on custom made Rize look-a-like bracket, MagnaFlow 4" turbo back exhaust with 6" chrome tip, Auto Meter Phantom II trans, pryo, and boost on the pillar, SCT from DJ, 20% tint on front and 35% over factory on rear and back glass, Carriage Works billet grill, 6000K Hi/Low HIDs in heads and silverstars in fogs, chrome tow hooks, LEDs in every stock location, 08 custom powder coated rear diff cover.
Project in the making: train horns!!!!
BVavra is offline
post #2 of 82 (permalink) Old 07-05-2007, 01:27 AM
BLING BLING
Blk350on20s's Avatar
Send a message via AIM to Blk350on20s
Yes a fuel system will give you some power but the main job for it with stock injectors is to make them last longer. It maintains fuel pressure at constant instead of spiking and dropping. I have Djs and love it. Gave me a lot better low end. Any body's system will work but if it has stainless braided lines they will all look cool. Ryan
08 F350 4x4 CCSB 6.4, 6" on 37s and 22s, Spartan DD w/ 310/KEM 345, Elite HPFP, Ported rails, EGR delete w/ wastegate, studs, CFM +, Rudys IC pipe, BD BOV, FASS 150 w/ custom fuel system, S&B intake, Rudys downpipe and DOC/DPF delete, CCV mod, Zex nitrous, Suncoast Trans, 1 piece drive shaft, Recon and tint everywhere. Under Construction
Blk350on20s is offline
post #3 of 82 (permalink) Old 07-05-2007, 01:29 AM
Robts's Avatar
I knowlaugh
2004F-SVT Lariat 2005 Cummins 5.9 conversion
August 2007 TDG Truck of the Month
Septmeber 2009 TDG Truck of the Month
2008 TDG Truck of the Year
2005 CR Cummins conversion with destroked motor mounts and tach module.
ARP Studs;Hamilton springs and pushrods
WickedDiesel DragonSlayer CP3 and 5x10.5 inj
Tsperformance MP8; Smarty S06 TNT-R
Speraco Inercooler; Opie Water by-pass;DTT intake elbow
Twin turbos
Grand rock 7" stacks
ATS Stage V 48re Transmission with billet output shaft and Co-pilot
Ford transfer case with ATS input shaft. Thanks to Sogrand for that
4.56 gears with Detroit truetrac. Custom Oasis Diff covers
FarmboyFabrication Ladder bars
(10) Autometer Gauges
6.5" Explorer Procomp lift with Fox Shox
37x13.5x22 Toyos with 22x10 Eagle wheels
2005 front end conversion with McColluch HID lights
Randy Ellias light bar with 4 procomp 130watt lights
Heat exchanger hood; limo tint, recon lights up top and on the mirrors
Optima. Yellow Tops; BilletBadges; Big special thanks to Walley at FTE
My Cummins conversion:https://www.thedieselgarage.com/foru...read.php?t=933
Robts is offline
post #4 of 82 (permalink) Old 07-05-2007, 04:57 AM
Dalpilot's Avatar
Images: 1
Me too.: I vote DJ's.
Dalpilot is offline
post #5 of 82 (permalink) Old 07-05-2007, 05:42 AM
Send a message via MSN to f350bart
yea, it helps, like stated saves stock injectors
03 f-350 6.0 leveling kit w/ 35's, sct from innovative, aem filter, 6in single stack, 4 pillar with fuel pres., boost, pyro, and trans temp, suncoast trans, spearco, studs, stock turbo w/ billet wheel, from brian at black widow, and 205cc injectors
f350bart is offline
post #6 of 82 (permalink) Old 07-05-2007, 11:40 AM
http://www.itpdiesel.com/store.php?c...on=show_detail That is the new fuel system from ITP and it removes there rear head bolts so it is a flow through design. it is one sweet setup. Just thought you might want to think about going down that route.
BlackSuperStroker33 is offline
post #7 of 82 (permalink) Old 07-05-2007, 12:05 PM
Dalpilot's Avatar
Images: 1
The problem with that one is it still uses banjo bolts. Get rid of those restrictions, and use a system with 90 degree elbows. Just my .02
Dalpilot is offline
post #8 of 82 (permalink) Old 07-05-2007, 01:03 PM Thread Starter
The ITP system looks like LIPD's system. I was going to get DJ's but I was looking around and finalizing my decision when I found LIPD's, and I liek the looks of there's better. It looks like they are all going to have about the same functionality with different looks and prices. I am still up in the air on which one to get.
BVavra is offline
post #9 of 82 (permalink) Old 07-05-2007, 01:19 PM
Send a message via AIM to HD_F250
I have DJ's as well, and love it. Great addition to the truck. It spools faster than it used too, runs smoother, and gained some bottom end. Also the MPH in the 1/4 mile went up so I know it added top end as well.
HD_F250 is offline
post #10 of 82 (permalink) Old 07-05-2007, 04:37 PM
vendor supporter
The main differences between lipd's system is a true regulated return system and dj's only feeds the front of the heads. I personally run lipd's system and can say it works great. Jason
SOLD
490.4 HP
870.8 TQ 13.2 @101 w/stock turbo and a set of 190's
blowin smoke is offline
