my first coolant loss - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Overthetop05, this thread has received 15 replies and been viewed 1911 times.
post #1 of 16 (permalink) Old 03-18-2008, 03:15 AM Thread Starter
ok 4 days ago i loaded my first insanity tune since it warmed up to 50 degrees to mess around. i didnt get over 1000 with my egts. i ran it around that day then i loaded it back to stock. it sat for a couple nights on a little angle with the front end down. i cheked the coolant before i left tonight with it and it was about at the bottom of the degas bottle i could barely see it. so ia dded it back up to the min. line. i looked for the whites spots there wasnt any puking out of the cap. looked around underneath for white spots like a leaking headgasket. nothing. i have no idea. will u please help. im clueless
2005 F-350 Blue Sport
Leveling Kit 18inch stockers
Silverline T/B 4inch 304
SCT Elite Tunes
Accufab Power elbow
SB Intake
ZOODAD
Overthetop05 is offline
post #2 of 16 (permalink) Old 03-18-2008, 03:19 AM
********* and Mafia #90
Bcarriveau's Avatar
it probably all just settled, there are days i have hardly any in my bottle, i fill it and it will spray out, so i just let if spray out till it stops and leave it, it wont puke then. you should check the coolant level when its hot IMO. when you open your cap after sitting for a wile is there any pressure in the system? you might have a leaking EGR cooler.
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #3 of 16 (permalink) Old 03-18-2008, 03:27 AM
allstarsixo's Avatar
I agree check the coolant when the truck is hot and when you pop the cap it will rise but make sure its at the min mark when hot and cap off. never add to it if the truck is cold because the coolant will expand when it gets hot. You should be OK if there is no white spots all over the engine. You will know when it spits out the degas tank .
Lonnie
allstarsixo is offline
post #4 of 16 (permalink) Old 03-18-2008, 03:30 AM
Bcarriveau's Avatar
07six-0 thanks i now feel good that i was doing it right. I never did like these sealed systems.
over the top, if you have your egt probe in the manifold 1000 is not hot at all. thats almost normal temps pulling a trailer. 12-1300 is when you want to be cautious.
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #5 of 16 (permalink) Old 03-18-2008, 03:46 AM Thread Starter
thanks guys ill keep my eye on it. ya i took the cap off after it sat and there was pressure
SCT Elite Tunes
Accufab Power elbow
SB Intake
ZOODAD
post #6 of 16 (permalink) Old 03-18-2008, 03:48 AM
Bcarriveau's Avatar
pressure is good, just keep it at the min line when hot and you will be fine, theres like a total of 3 gallons of more in these things,
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #7 of 16 (permalink) Old 03-18-2008, 08:10 AM
also check on level ground. If the back is lower or trk is leaning to the rt it will show its low.
heavyhaller is offline
post #8 of 16 (permalink) Old 03-18-2008, 09:02 AM
I found out the hard way not to overfill mine, after it puked and i got worried. then start reading puking post's. I had filled my resivor to the full line and shortly after it came back out. so i cleaned up the mess and left the coolant level alone. and no more puking.
Scott
SmokingIDI_7.3L is offline
post #9 of 16 (permalink) Old 03-18-2008, 05:58 PM
I Wanna Go Fast!
brentos's Avatar
It sounds like your fine, Do you like tadds tunes? i lovem I have only got mine to puke when i let it shift into overdrive and lay in it without it downshifting. I can hammer on it all day if it downshifts without puking at all. Yet im still pretty sure my hg's are going byby
brentos is offline
post #10 of 16 (permalink) Old 03-19-2008, 12:43 AM
Thats when mine puked, it only did it when the truck did'nt down shift!! I still would like to try another tuner's custom SCT (maybe DJ's)
Lonnie
