edge insight - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by droolinforparts, this thread has received 7 replies and been viewed 1275 times.
post #1 of 8 (permalink) Old 03-22-2008, 03:17 AM Thread Starter
droolinforparts's Avatar
Send a message via AIM to droolinforparts
edge insight
does the edge insight monitor the fuel pressure and oil pressure...and if so are they reliable?...i would like to get it but i know it would be going thru the ecm to get the peramiters and the oil pressure sensor only gets to a 7 psi and says that it is normal(acording to the 6.0L bible) does it do the same for fuel pressure...or would i be better off with normal gauges. Thanks.
'03 F250 XL 6.0LK&N intake, mbrp 5" stacks, SCT X3 with tunes from innovative, 6" superlift, 315-75r-16,boost, pyro, fuel pressure, oil pressure gauges all in the a-pillar,h-11 studs, short throw shifter,fass 95/150 with complete custom fuel lines, south bend clutch, traction bars
Singles #118
B.O.M.B Squad #28
droolinforparts is offline
post #2 of 8 (permalink) Old 03-22-2008, 04:13 AM
strokin6L's Avatar
I have the insight on my truck and it doesn't monitor fuel pressure. But i was told that edge is working on a way to do it. As for the oil pressure, not really sure, but i think it can monitor oil pressure.
strokin6L is offline
post #3 of 8 (permalink) Old 03-22-2008, 04:41 AM
For now its not available on the Insight. You maybe better off doing standard gauges or getting the Quadzilla Commander with the fuel pressure gauge kit.
You can see them here:
http://www.dfuser.com/mfg/other/gauges.php
Thx,
Bill
dfuser is offline
post #4 of 8 (permalink) Old 03-23-2008, 12:42 AM Thread Starter
ok thanks guys...does autometer make an oil pres. gauge and a pyro that goes a little above 16...i just don't want to see it peged most of the time (i live where you cant avoid a hill that is like a water slide but longer) Thanks
Singles #118
B.O.M.B Squad #28
post #5 of 8 (permalink) Old 03-23-2008, 01:13 AM
strokin6L's Avatar
autometer does make an oil pressure gauge. As for an autometer pyro that goes above 1600, they make one that goes to 2000 degress if that's high enough for ya.
post #6 of 8 (permalink) Old 03-23-2008, 08:42 PM Thread Starter
yep that will work now do you know who carrys them because i haven't seen them....and where would you put the fitting for the oil and fuel pressure...on the filter caps?
Singles #118
B.O.M.B Squad #28
post #7 of 8 (permalink) Old 03-23-2008, 10:30 PM
strokin6L's Avatar
You can get them from summit racing. You could drill and tap the plastic caps but you could also get billet caps from elite or DJ that are already drilled and tapped for this. But i think you can use a port on the engine mounted fuel filter housing for the fuel pressure.
post #8 of 8 (permalink) Old 03-24-2008, 12:26 AM Thread Starter
thats what i was going to do get the two billet caps for under the hood and get a second oil cap because from what i have heard it is the same as the primary fuel filter...thanks abunch for all your help
Singles #118
B.O.M.B Squad #28
